Epson Home Cinema 8100 LCD Projector Review
- Product Name: Home Cinema 8100 Projector
- Manufacturer: Epson America
- Performance Rating:
- Value Rating:
- Review Date: May 06, 2010 08:40
- MSRP: $ 1499
- Specifications
Brightness: 1800 ANSI lumens (Dynamic mode)
Contrast: Up to 36,000:1 (full on/off)
Resolution: 1920 x 1080 native HD resolution
Aspect Ratio: Widescreen native 16:9 aspect ratio (4:3 resized)
LCD Panel: 3 x 0.74" D7 C2Fine
Optical System: Dichroic mirror separation and prism combine method
x.v.Color support
Video Inputs: HDMI 1.3a x 2, component, composite, S-video, and PC/RGB (HD15)
Video Processing: HQV Reon-VX
Control: RS-232C, IR remote, 12 VDC trigger output
Projection Lens: Fujinon lens F/2.0 - 3.17, manual focus & zoom (1 - 2.1)
Lens Shift: Vertical and horizontal (96% vertical, 47% horizontal)
Lamp: 200W UHE (ultra high efficiency) E-TORL; 4000 hours (low mode)
Power Supply: 100-120 volts, 3.3A
Power Consumption: 285W (high); 0.2W (standby)
Operating Temperature: 32 - 104 degrees F (0 - 40 degrees C); 20-80% humidity (no condensation)
Fan: 22-28dB operation (in low mode)
Remote Control: Backlit w/batteries included
Standard Accessories: Power cord, Wireless remote control unit, batteries for remote control
Warranty: 2 year parts and labor limited warranty, 90-day lamp warranty, including overnight replacement services and exclusive Epson PrivateLine toll-free technical support (U.S. and Canada only)
Dimensions: 17.7" x 15.5" x 5.7"
Weight: 16.1 lbs
- Excellent blacks
- Great value
- Individual controls
- 2.1x zoom Fujinon lens
- Quiet
- Default color not accurate
- Green outside of ATSC gamut
- No anamorphic mode
Introduction
Discussion Thread
Response (Jesus A) 08/18/2010 03:25 PM
Dear David,
Thank you for contacting Epson regarding your incident.
The Home Cinema 8100 does not use the HQV processor. It uses a PixelWorks processor. The projectors that use the HQV processor are the units that had the UB designation, like the 8500UB.
Should you require further assistance, please reply and reference incident ID: 100816-002813. If you have a different support issue, submit a request via our U.S. or Canada Support Site and we will respond in a timely manner.
Thank you again for contacting Epson.
Jesus A.
Question Reference #100816-002813
Escalation Level: Manila Unassign Incident
Product Level 1: Projector - Home Theater
Product Level 2: Epson PowerLite Home Cinema 8100
Category Level 1: None
Date Created: 08/16/2010 12:14 PM
Last Updated: 08/18/2010 03:25 PM
Status: Resolved
ie: What does the offset mean when it comes to a 100" diagonal screen? (I know this, but others may not)
What is the actual brightness of the projector and what environments is that amount of brightness, and at what screen size, is it usable?
How well will the remote work within a universal remote system? Sometimes the on/off is really tough to deliver with a single power button.
What models are comparible? The 6500UB is discontinued, so what is the real competition for this model and at what price point? Viewsonic 8100? Optoma HD20? BenQ W1000? Other?
Is there frame interpolation on this model? How does it perform if so?
Really, just a few questions that I think would be good to answer and help people with their buying decisions. This is one of the best reviews overall that I've read and I have no issues with the scoring/rating which I typically like to complain about. I've not installed one yet, but will be doing so hopefully in the next month or so. The 8100, in my opinion, is one of the best super flexible install projectors available. The lamp life is better than average, and it has good brightness. Image processing could be better, but is not inappropriately poor either. Feed it a good source (Blu-ray, high quality upconversion) and you will get a good image.
A blurb on organic vs. inorganic panels is also necessary since most people are unaware that the inorganic LCD panels, as used on the big brother 8500UB and the old 6500UB are designed to last longer compared to the organic LCD panels which the 8100 uses.
I am a bit suprised that the 8100 is being compared so much to the 6500UB, when it is designed as the replacement for the 6100. In almost all regards it's an upgrade on the 6100, which was no slouch either, and comes in for less money there as well.
Good stuff on this review and people really should be putting this projector way up there if they can hit the price point for it. Epson has really been putting out some nice product in the past few years for the home theater market.
mpompey;717371
How big is your screen exactly? Did you encounter any issues with your 8100? Did you get the 8100 or the 8100 UB?
I never said I had an Epson, let alone 8100/UB. I don't want to go too off track in this thread based on the 8100 review; I only jumped in for a moment to lend my help towards a particular post. If you have more questions regarding my setup, please free to continue via PM. FWIW, my PJ is not always known to be exceptionally good with motion, but it's fine for me, and my guests. In fact, I'll send a PM now.
