You are here: Home Pro Reviews Projectors BenQ Joybee GP1 LED Projector Review Joybee GP1 Build Quality and Menu
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified June 16, 2009
GP1-angled.jpgProjectors have gone through several iterations in the time I've been around. From old, clunky CRT systems to DLP and LCD systems, projectors have gotten brighter, smaller and more feature-rich. But with the introduction of the BenQ Joybee GP1, LED lighting is now taking front projectors where they have never been. With LED lighting, even a DLP projector can be smaller, lighter and more versatile than its UHP or similarly lighted counterparts. The projector is literally smaller than a stack of CDs, smaller than a Mac Mini, and smaller than my outstretched hand. Yet this incredibly tiny projector puts out 100 lumens from its single LED lamp, making it bright enough to light up an 80 inch screen in a darkened room. The resolution is SVGA (858x600) so you can't expect high definition resolution, but this projector is perfect for those quick presentations, parties, or even quick movie nights with the family. While the native resolution is SVGA, computer resolutions from 640x480 (VGA) up to 1280x1024 (SXGA) are supported.
She's a Brick… House
For something that takes up the same volume as your average brick, the Joybee GP1 packs a lot of features and power. Measuring roughly a 5" square that is just over 2" deep, the GP1 is as lightweight as it is small in stature. The top of the projector has a circular control panel reminiscent of a generation-1 iPod. The controls are touch-sensitive, with power in the middle and directional arrows all around. Volume can be controlled from this panel and there are buttons for all menu functions as well as blanking the output and changing projector modes. At the front corner of the GP1 is the focus ring (there is no zoom) which can focus the projector when the screen size is between 15" and 80" in size.
Fortunately for us power users, the GP1 comes with a credit card-style remote control which allows much more consistent control over the projector than the sometimes (OK, often) touchy capacitance controls of the unit itself. Because of the sensitivity of the touch controls, we latched onto the remote pretty quickly and didn't let go. The remote is very basic, and the separate controls for the USB reader were a bit odd, but seemed to give more capability to the remote so you could accomplish more without having to go back to the main setup menu. We liked the dedicated Source button and the Power button consistently shut down the projector in less than 2 seconds flat.
Connections
The BenQ Joybee GP1 has minimal connections. With the included iPod-like multi-pin adapter you can input composite video with stereo audio, or send the projector a VGA signal (the RCA audio will still allow audio input. If you purchase the optional iPod/iPhone universal dock you can also send audio and video to the projector directly through the multi-connector. There is also a stereo audio output should you want to output that audio to your AV receiver/home theater.
Menu System
The menu system is icon-based and far more complex than I would have imagined. There are six main menu sections: Display (Keystone and other macro controls), Picture (Brightness, Contrast, Sharpness, etc), Source, Basic Setup (Language, Position, Timers), Advanced Setup (Audio, Menu & Security settings), and Information (Status and FAQs). What surprised me the most was the auto keystone, which worked very well and had a full +/- 40 degrees of digital adjustment. I never suspected this would appear on a palm-sized projector. Using the menu via the projector is a tad difficult, but it was much easier with the remote.
