Sherbourn PT-7000 Processor and 7/2100 Amplifier Review
by Gene DellaSala last modified January 05, 2007
Sherbourn PT-7000 processor
  • Product Name: PT-7000 Processor and 7/2100 Amplifier
  • Manufacturer: Sherbourn Technologies
  • Review Date: January 05, 2007 09:22
  • MSRP: $ 4200
Specifications
  • 7.1 Operation
  • Bass Management: Crossovers at 40 Hz to 150 Hz
  • Input Impedance 26-kOhms
  • MFR: 10 Hz - 20 kHz - 0.5 dB
  • Component Video Bandwidth: 55 MHz - 3 dB
  • Rated Output: 2 Vrms
  • THD: 0.0035%
  • Dimensions: 17.1" W x 4.6" H x 14.8" D
  • Weight: 17.6 lbs
  • Power output per channel: 200 W into 8-ohm, 300 W into 4-ohm
  • THD: <0.05% at 8-ohm, <.075% at 4-ohm
  • Output load impedance: 8- or 4-ohm in normal mode, 8-ohm minimum in bridged mode
  • Input load impedance: 20 kohm (balanced or unbalanced)
  • Input sensitivity: 1.1 V (balanced or unbalanced)
  • Power bandwidth: 5 Hz to 75 kHz
  • S/N ratio: 100 db wideband, 110 db A-weighted
  • Power requirements: 120 V, 2 x 15 A
  • Dimensions: 19" W x 7" H x 17.7" D
  • Weight: 115 lbs (gross)
  • Easy to operate
  • 6CH input bass management
  • Excellent sounding in all modes of operation
  • Custom installers dream amp
  • Superb Performance
  • Endless dynamics and power reserves
  • Triple crossover erroneous operations
  • Limited to 1dB channel trim accuracy
  • Limited to global channel trim and bass management settings
  • 12V trigger interface different from mating processor
  • Very heavy, complicated set-up
Introduction
It is obvious by the latest product offerings from Sherbourn that they understand the current industry trends, and as a result they have managed to intelligently design high performance products that fit quite nicely. Enter the PT-7000 7.1 Channel Preamp/Processor (MSPR: $1500) and the 7/2100 7CH 200wpc Power Amp (MSRP: $2850). This combined duo retails for $4350 and weighs in at a whopping 140lbs! At this price point, your alternative options are flagship receiver such as those from Denon, Pioneer Elite, B&K, etc, or separates from other manufacturers such as Outlaw, Adcom, Rotel, etc. This is an interesting price point to compete in as it is where a threshold is crossed between flagship home theater receivers and entry level separates.
