You are here: Home Pro Reviews A/V Processors Parasound Halo C2 Processor Review Parasound Halo Overview and Build Quality
by Steve DellaSala last modified December 07, 2006
Parasound, a privately owned U.S. company located in San Francisco , was founded in 1981. From their inception by President, Richard Schram, their mission has been to provide affordable audio components for high-end audiophiles, home theater enthusiasts and custom audio/video systems designers.
During an interview, Richard Schram once stated that, "we take listening very seriously," and we're sure that this philosophy likely resulted in the fundamental reason why Parasound created high quality products made to endure the scrutiny of most audiophiles while being affordable to the budget minded enthusiast. "If I didn't listen to the products we sold, or if John Curl, our legendary chief circuit designer, didn't listen to the products he designed, then we would have never won the respect of hundreds of dealers, the praise of most of the world's audio reviewers, and the earned loyalty many thousands of critical listeners who have chosen Parasound products for their own."
Parasound's chief designer for their amplifiers was John Curl. Curl's experience included hardware such as the classic Mark Levinson JC-2, the SOTA head amplifier, and the Vendetta preamplifier. He also wrote several definitive articles on circuit design and the influence of capacitor design on sound quality. Lately however, Curl has been promoting some views on cables which Audioholics does not agree with, but we believe this seemingly new found position didn't take away from his excellent circuit designs and understanding of the important metrics governing quality amplifier designs as seen in the Parasound A 21 and A 51.
Parasound introduced the Halo C2 and C1 in 2002, and both have been highly regarded among many audiophiles and professional installers not just for sound quality, but also the many unique features they offer. Features such as BNC video connections, video signal pass through (which allows video signals to pass through without the C2 power being on), customizable Aux channels, automatic calibration (which included automatically setting speaker distances and volumes), easy to use set-up menu, firmware upgradeability, software programmable all controlled by a sophisticated Universal MX-700 Remote Control (including a "Side-Kick" Remote), are simply not common place for many processors. For those who desire additional bells and whistles, the C1 even includes a 5" front panel TFT display for on board display of the setup menu along with extra filters and a more robust the power supply. Perhaps some of the increased power supply in the C1 may be used to run the 5" TFT, but it may also offer sonic performance improvements beyond that of the C2.
Front Panel Screen
Perhaps the obvious difference between the C1 and the C2 could be seen by the height, which made way for the 5" flat panel screen on the C1. The screen would probably come in very handy when setting up the C 1 in with a front projector especially when the C 1 is located on the same wall as the projector screen. The on-board flat panel display mimicked the On-Screen Display and could either be operated via the remote or on the buttons located directly on the C 1's front panel. Both methods proved to be extremely useful for the times we needed (or wanted) to set up the C 1 without a monitor. For example, I used this panel display quite a bit when listening to two channel CDs where I didn't want the distraction of my large Rear Projection Monitor but still required setup and configuration tweaks to optimize the sound, or switch the DSP modes. The OSD also had a "Temp Display" that could be set to "Full" or "Simple." In "Simple" mode, the C 1 displayed only the specified function, such as the DSP type, Input Selection, Volume and other line item functions. When set to "Full" the unit displayed the entire menu from the On-Screen Display.
The Front Panels of the Halos could also be adjusted in brightness. The C2 allowed for the display to be completely turned off or adjusted to three different brightness levels. The C 1's flat panel display could also be dimmed but it was not able to be completely turned off. Even in the lowest dim setting, there was a faint glow from the panel which could be seen peripherally when viewing movies in the dark if the unit is located to the side of the screen as was the case in Reference System 2. The dim setting adjustment for the flat panel display also varied the brightness of the text making it a bit harder to read in the dimmest settings.
Digital Architecture
What Audioholics review would be complete without our peak under the hood? The digital architecture of the Halo C 2 and C 1 included four dual channel AKM's AK 4393 Digital-To-Analog Converters and one Motorola Symphony 56367 24-Bit DSP. This Motorola DSP is common in several other receivers and processors from companies such like Aragon and Anthem.
Power Supply
What seemed to be missing from our look inside was the typical larger and heavier linear power supply we've seen in many other processors. In its place was a computerized digitally switching power supply which was the fundamental reason for the Halos lighter than average 18-lb (C 2) and 22-lb (C 1) weights. When we asked Richard and Tony Pointes (Head of Technical Department) about this power supply, they pointed out the following. One advantage of this design was that the Halos were able to automatically switch to different input voltages making them ready for an international marketplace. According to Parasound the digital switching power supply also proved to be more efficient by converting the frequency to much higher rates than the standard 60-Hz. Aside from the front panel display, the power supply is another differentiation for the C1 and C2 as Parasound informed us that the C 1 included additional filtering. Some of this was likely used to operate the TFT display
Enhanced Bass
The Halos included a very useful feature called "Enhanced Bass" which sends bass from channels set to "large" to the sub simultaneously. This feature was particularly useful when listening to two channel CD playback or Satellite TV, as it provided extra bass sound with the push of one button on the remote. However, when the front channel speakers were set to "small," the sub remained on at all times regardless of the menu which still allowed for "On" or "Off" to be selected. This was a bit confusing at first and it would have been a bonus feature to actually be able to control the Enhanced Bass with "small" speakers. The Enhanced Bass "On" and "Off" could also be toggled when switching to 7.1 channel inputs, but since the signal was bypassing the digital circuitry, it too was defeated though still selectable. While this wasn't the end of the world, it could be confusing to many operators thus why we noted it in our review.
Direct Mode
For most AV Controllers "Direct Mode" usually means Analog Mode or "Pure Direct" Mode but on the Halos, it actually referred to the mode of the source. Using the Direct mode allowed the C 1 and C 2 to automatically select the appropriate digital format for a digital source signal including stereo, mono, Dolby Digital,... and DTS.
7.1 Channel Analog Inputs
The Halos provided one set of 7.1 channel inputs for DVD-Audio and SACD. Unfortunately, there was only one set of global speaker level settings which made it challenging to switch between the two formats as the subwoofer outputs vary. So when switching, from one to the other, we had to adjust the subwoofer level volume by ear using just the On-The-Fly adjustments.
Other Analog Inputs
Both the Halo C 1 and C 2 came with 10 additional unbalanced analog inputs (via RCA) which could be used for CD players, turntables, VCR (for those still living in the past), and any other analog source of interest. It's important to note that these were processed in the digital domain. The Halos did provide pure analog inputs which bypassed the digital circuitry via a set of balanced XLR analog inputs and the 7.1 channel unbalanced RCA analog inputs. So in order to remain in total analog, it required using either of these connections.
Rack Mounting Brackets
I was pleased to see both the C1 and C2 offered brackets which could be easily installed on the units to make them ready to mount into a standard 19"-wide rack. This was likely provided for the custom installers and Audiophiles who don't just furnish their products, but solidly bolt them on to something robust and sturdy.
The Many Modes of the Halo
The Halos came equipped with an array of different modes which included all the basics.
Dolby Modes include:
  • Pro Logic
  • Pro Logic II Movie and Music
  • Dolby EX
THX Processing
  • Cinema
  • Surround EX
  • Ultra2 Cinema
  • MusicMode
DTS Modes include:
  • Neo: 6 Cinema
  • Music
  • Matrix
DSP Modes
  • Natural
  • Party
  • Club
  • Concert.
