You are here: Home Pro Reviews A/V Processors Emotiva DMC-1 Preamp Processor Review DMC-1 Measurements and Analysis
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified February 12, 2007
The frequency response via the analog outputs of the DMC-1 are ruler flat out to about 50kHz with a -3dB point of around 200kHz.
When the analog preamp was driven at 1Vrms (typically ½ signal strength to achieve ½ of max power of most power amps with voltage gain of 29dB) distortion levels were (+.0.18 + 106.062)dBv = 106.242dBv or 100*alog(-106.242/20) = .000487%. This is excellent performance for a preamp.
When the analog preamp was driven at 6Vrms (more gain than you should ever need to drive any power amp to maximum power) distortion levels were (+.15.761 + 76.607)dBv = 92.368 or 100*alog(-92.368/20) = .00241%. Again this is excellent performance and indicates distortion is not an issue with this preamp at any unclipped drive level.
Signal to Noise Ratio Tests
Using the EXT 8CH Input and setting the source to 200mV in, and adjusting the output of the D M C-1 until it produced 1Vrms Output, we measured the following:
-105.703dBra without signal
-19.448dBra with signal
< 10 Hz - 22k Hz bandwidth , no option filter.
SNR: 86.3dBra (unweighted)
This is very good performance. Though a few dB shy of what we consider stellar noise performance for a preamp we never heard any noise issues in real world listening tests. This is a marked improvement over what we observed when we conducted our review of the Sunfire Theater Grand III.
At Max Output
Ch-A SIGNAL to NOISE RATIO
-105.86 dB below 16.46 dBV or 6.6Vrms; Reference Level (at 0.10 % THD+N)
Via CD Analog Input (A/D conversion)
210mV in, 1V out
-94.122 without signal
-19.531dBrA with signal
SNR: 74.6dBrA (unweighted)
As you can see, going through ADC to DAC conversion stages on native analog signals adds about 12dB of noise. We recommend using the digital inputs on the D M C-1 on sources (assuming they have digital outputs) you wish to add DSP processing to for the best possible performance.
Subwoofer Output
Subwoofer output distortion was significantly higher than the rest of the preamp outs, though likely inaudible due to our ears perception of distortion at low frequencies. It was about .15% at all unclipped levels and reached clipping about +7.5Vrms which is more gain than you will likely use in any application.
Maximum Preamp Signal Levels
The processor outputs provided maximum output levels 6.6Vrms unclipped and accepted a maximum unclipped input signal of 5.5Vrms.
