You are here: Home Pro Reviews A/V Processors Cary Cinema 6 AV Processor Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Christine Tham last modified January 14, 2006
Cary Cinema 6 Processor
  • Product Name: Cary Cinema 6 AV Processor
  • Manufacturer: Cary Audio Design
  • Performance Rating: StarStarStarhalf-star
  • Value Rating: StarStarStar
  • Review Date: January 14, 2006 19:00
  • MSRP: $ 2500
Specifications
Decoding ability: Dolby Digital, Dolby Pro Logic IIx for movies and music, Dolby Digital EX, DTS ES 6.1 Discrete, DTS NEO 96/24 for movies and music, Matrix Surround for 5.1, 6.1 or 7.1, Dolby Pro Logic II for movies and music for 5.1 system installations
Inputs: 4 S-Video, 4 Composite video, 3 Component video, 5 analog audio stereo pairs, 4 RCA coaxial digital, 4 TOSLINK digital
Surround Sound Modes: 7.1, 6.1, 5.1 for movies or music with dual 7.1 analog bypass input sets for SACD or DVD Audio multichannel playback
Outputs for speakers: Main Front pair, Center Front, Surround Back pair or Center Surround, Surround pair, Sub Woofer, can have 5, 6 or 7 speakers & sub.
Detailed Features: Analog Stereo Direct switching, 4 music modes for stereo surround, live sports viewing, RS-232 port on back panel for custom install system control, IR repeater input and output, 3 remote DC triggers, Bass and Treble controls with bass management circuit, Variable crossover from 40-140 Hz, in 10 Hz steps, 300 mHz video bandwidth for high definition DVD or Hi-Def cable or satellite video switching in the component video section, can upsample 2 x Fs for digital audio inputs, dedicated remote control handset for Cinema 6 operation, Second zone audio and video outputs, 1 Component video output, S-Video and composite video On Screen menu displays outputs, all analog inputs and outputs are with RCA jack connections
Video Signal Resolution: 540 TV Lines
Signal Format System: PAL (625/50, 525/60), NTSC (525/60, 625/50)
S-Video Output: Luminance Signal: 1 V p-p (75 Ohm load), Color Signal: 0.286 V p-p (75 Ohm load)
Component Video Output: Y Output Level: 1V p-p (75 Ohm load), Cb Output Level: 0.7V p-p (75 Ohm load), Cr Output Level: 0.7V p-p (75 Ohm load)
Frequency Range: 2 Hz - 96 kHz
Amplitude Linearity: +/- 0.2 dB (20 Hz - 20 kHz)
Phase Linearity: 3 degrees(20 Hz - 20 kHz)
Dynamic Range: 115 dB (1 kHz)
Signal-to-Noise Ratio: 115 dB (1 kHz)
Channel Separation: >100 (1 kHz)
Total Harmonic Distortion: 0.008% (1 kHz)
Rated Output Level: 1.0 V rms (8.0 volts maximum)
Power Input: 120 or 240 Volts AC, 50-60 Hz
Power Consumption: 25 Watts
  • "No compromise" audiophile quality analog pre-amplification
  • Perfect handling of 0dBFS+ levels in digital playback
  • Support for Dolby Pro Logic IIx and DTS NEO 96/24 formats
  • HDCD and 2x upsampling support
  • Support for 192 kHz optical/coaxial digital input
  • Mediocre digital playback
  • No support for HDMI or IEEE1394 AV input or switching
  • No digital line level outputs
  • Zone 2 outputs are fixed level and switches the analog inputs only (no conversion of digital inputs to analog)
  • No THX certification
  • No support for Dolby Headphone or Virtual Speaker
  • No digital room correction
  • No digital processing available on analog inputs
Introduction
Cary Audio is company probably better known for their SET (single-ended triode) power amplifiers and vacuum tube pre amplifiers (and lately, some remarkably fine sounding CD players). But it seems Cary wants to be considered in the highly competitive home theater market as well, releasing a line of DVD players, processors/preamplifiers and multi-channel power amplifiers.
