You are here: Home Pro Reviews Power Conditioners Furman Elite-15 Power Filter Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Ray Adkins last modified October 01, 2006
  • Product Name: Elite-15 Power Filter
  • Manufacturer: Furman
  • Review Date: October 01, 2006 20:00
  • MSRP: $ 299
Specifications
AC Current Capacity:
Input - 15 Amp capacity required
Output - 11-15 Amps RMS (maximum, all outlets combined - continuous)
Linear Noise Attenuation:
Transverse (Differential) Mode:
> 40 dB from 10Khz. - 100 kHz. >80 dB from 2 Khz. - 100 kHz. – 1GHz.
(Linear attenuation curve from 0.05 – 100 ohms line impedance)
Outlets:
1 (linearly filtered outlet - front panel)
2 (linearly filtered outlet - rear panel)
4 (linearly filtered outlets with additional ultrasonic filtering for digital or video components)
Transient Voltage Surge Suppression:
120 VAC - Series Multi-Stage Protection - Non-Sacrificial with Zero Ground Contamination.
Extreme Voltage Shutdown
Telco
Cable / Satellite (less than .1dB insertion loss)
Dimensions:
2.15” H x 17” W x 14.75” D (Standard 1 RU height without feet)
Weight:
11 lbs.
Power Consumption:
6 Watts for display and control circuits independent of actual load.
Safety Agency Listing:
NRTL-C
Warranty:
The Furman Elite-15 is protected by a three year limited warranty covering defects in materials and workmanship. (see manual for details)
  • Excellent, Highly Engineered Build Quality
  • Non Self Sacrificing Surge Protection
  • High Bandwidth Satellite/Cable Connection
  • Pull-out LED rack lights are convenient
  • 3-Year Warranty
  • Great value
  • May not have enough outlets for bigger home theater systems
  • No amplifier triggers
  • No voltage regulation
Introduction
Being addicted to audio, video and home theater is a life long habit for which there is no cure. Once you get a taste, you are officially part of the audio/videophile habitual users’ club. Being hopelessly addicted, you now spend countless hours thinking of ways to improve your system. Spending hundreds and even thousands of dollars on the next piece of gear to improve your system, you finally reach the point of diminishing returns. All is well until the first power surge or lightning storm turns your A/V masterpiece into something that more resembles abstract art.
