CyberPower PR1500LCDRTXL2U UPS Review
- Product Name: PR1500LCDRTXL2U UPS
- Manufacturer: CyberPower
- Performance Rating:
- Value Rating:
- Review Date: June 10, 2009 02:25
- MSRP: $ 736
- Specifications
- Voltage: 80Vac - 150Vac
- Cord Length: 10'
- Output: 1500VA/1000W
- Automatic Voltage Regulation
- On Battery Voltage: 120Vac, 50/60Hz (+/-5%)
- Pure sine wave
- Outlets: 8 NEMA 5-15R (battery & surge protected)
- Outlets - Critical Load: 4
- Overload: Internal circuitry limiting / circuit breaker
- Transfer Time: 4ms
- Runtime at Half Load: 24 min.
- Runtime at Full Load: 9 min.
- Optional BP48V75ART2U battery packs avail.
- Battery (HR9-12): 12V/9Ah, Sealed lead acid (hot-swap) x 4
- Recharge: 8 Hours
- Surge Suppression: 2,060 Joules
- Phone / Ethernet (combo) RJ11 / RJ45: in/out
- Coax RG6: in/out
- EMI/RFI Filtration
- LCD Diagnostic Display (Load/Current Level, Runtime, Battery Level, Temperature (F & C), Battery In Use, Input Voltage, Output Voltage, Output Frequency, Overload, Wiring Fault, Battery Shutdown Voltage, Static Frequency Tolerance, Slew Rate, Silent Mode, Normal Mode)
- HID Compliant USB Port
- Serial Ports: 2
- LED Indicators: Power on, wiring fault
- Audible Alarms: Input fault, battery fault, low battery, overload
- Software: PowerPanel Business Edition
- SNMP / HTTP Remote Monitoring (with optional RMCARD201)
- Emergency Power Off (EPO) Port
- Dimensions (WxHxD): 17.25" x 3.5" x 19.5"
- Rack Size: 2U
- Weight: 70 lbs
- Certifications: UL1778, cUL 107.1, FCC DOC Class B
- ROHS Compliant
- Warranty: 3 Years Limited
- Connected Equipment Guarantee: Lifetime ($400,000)
- Large LCD status screen
- Ample power
- Dual PC control
- Remote monitoring
- No high-bandwidth RF protection
Introduction
When you invest in electronics, be it for the home theater or for the home office, battery backup is something that should not be left out of your budget. In these days, when time equals money, it's unthinkable that a lightning strike, random brownout or other electrical snafu could cost you hours of work or even thousands of dollars in equipment. CyberPower's PR1500LCD UPS will guarantee your work doesn't get wiped out when someone down at the local power station decides to trip over an extension cord, or a squirrel forgets that running the Nutty 500 race across a wet power line might not be the best decision he's made all week.
See also:
Recent Forum Posts:
zumbo posts on November 26, 2010 20:29
I use a Cyberpower PR2200LCDRT2U. There is no noise added to my system. Fans only run if there is a power outage. Of coarse, I shut my system down after the outage. SAFELY.
I can't imagine how many times this component has saved another component in my system. It is priceless. It will also kick on during crazy insane volume levels. Usually rocking by myself when that happens. If the fans come on then, there is no way I could hear them.
http://www.pcnation.com/web/details.asp?item=T14236 [pcnation.com]
ZIPPO posts on November 07, 2010 13:11
Did the PR1500LCDRTXL2U have an audible hum/buzz? What about fan noise?
I recently purchased a CyberPower UPS( OR500LCDRM1U ). I had to return it, because it was too loud( audible hum ).
nibhaz posts on June 09, 2009 08:57
Am I missing something...there appears to be just the intro?
