You are here: Home Pro Reviews Portables & Media Boston Acoustics MicroSystem CD Review MicroSystem CD Build Quality and Remote
by Tom Andry last modified March 16, 2007
BA_MicroSystem_inboxWhen one gets used to great audio, it is hard to stomach little else. After spending thousands on a home theater setup, a two channel rig, a decent pair of cans (headphones) and a headphone amp… well, perhaps your finely tuned ears are just too delicate for a simple Wal-Mart special clock radio. You need something a little more… refined. The Boston Acoustics MicroSystem CD is much more than just a clock radio, this unit purposes to be able to take “tabletop performance to the next level, with big, rich sound you never thought possible in a system this size.” Gee, I think I’ve heard this one before… but where? Hmm… Well, we’ll deal with that later. What is most important here is 1) how it sounds, 2) How it looks and 3) how well it works.
Build Quality
BA_MicroSystem_frontThe MicroSystem CD is heavy for its size (most DVD players don't weigh 6 pounds!) and feels very sturdy. It arrived in a colorful box that should be very eye-catching on the shelf of your local electronics store. The review unit is black (charcoal) but it is also offered in white. There are speakers on either side with a port on the rear of the unit behind each of the drivers. The unit had a very low profile but is a little wide (good for separating the speakers for stereo response but bad for placement) so it may take up a bit of real estate on your dresser/nightstand. There is an attached power cord, a removable FM “wire” antenna, and a removable internal AM antenna. The AM antenna is plugged in externally but the antenna itself is located inside of the unit. This allows you easy access to the connection so you can disengage it if you’d rather us an external antenna. On the back of the unit there are two inputs and one line out (in case you feel the need to use this unit as a transport or you want to connect a subwoofer). There is also an 1/8th inch stereo input on the front that is designed to be utilized with iPods/MP3 players. A headphone jack is dangerously close to the iPod input with labels that are only legible when you are up close in bright light. There is a compartment on the bottom for a 9 volt “backup” battery.
IMG_4159The front display dims under low light conditions which is still easily readable from across the room. I found that in my room, every time my shadow fell across the unit, the display would dim. This was neat in that it showed how responsive the dimmer function was, but also a little disconcerting. I’d always seem to see it out of the corner of my eye but by the time I got my head around to see what it was, the light would pop back on to full strength. Watch The Ring or a similar movie and then have that happen to you. I was afraid to answer the phone for a week. I found out later that the amount of light that triggers the dimming function can be adjusted manually by pressing and holding the Info button while adjusting up and down the level with the Volume buttons.
BA_MicroSystem_back1The back of the unit has a “Bass Trim” knob which can be used to attenuate the amount of bass coming from the unit. Since this unit is designed to maximize bass output, placement near walls/structures could create an overly “boomy” bass experience. The Bass Trim knob can be used to reduce the amount of bass if you can’t pull the unit away from the structures.
The drivers are 3” paper cone woofers. From the outside (through the grill) I thought they were coaxial but I was wrong. Behind each woofer is a cavernous space with only a modicum of polyfil to keep the cables from rubbing. Each side feeds into a small “port” which exits the rear of the unit. The electronics seemed densely packed into the enclosure with very little space that was not utilized by a circuit board, output device, or the monstrous toroidal transformer - very unlike the cavernous spaces found in most set-top radios. Overall, it is a very solidly built machine.
BA_MicroSystem_electronics     BA_MicroSystem_CD_ports
BA_MicroSystem_driver1     BA_MicroSystem_driver2
Remote
BA_MicroSystem_remoteThe remote hides neatly away in the fold down face of the unit. Honestly, this placement is so cool, I find myself using the remote even when I’m standing directly in front of the unit just so I can fold down the front. The remote is slightly larger than a credit card and about a 1/4 inch thick. It charges by sitting in its magnetic cradle. The buttons are bulbous and present a bit of resistance when pressed. There is no backlighting which for the most part isn’t a problem. You can even browse your folders on your iPod/MP3 player from the remote. The layout is fine though I wouldn’t mind seeing the 1-6 preset buttons being usable for track selection when controlling the CD (yes, I know it would only work for the first 6 but who cares?) It would also be nice if the “sleep” button were lighted so that you could see it if your alarm is set early. Of course, there is some value to making people get up (or turn on a light) so that they actually wake up. I know that I’m famous for turning off the alarm, lying back for “just a second” (I tell myself), and waking up hours later.
Recent Forum Posts:
muellerguy posts on January 02, 2008 16:25
I'm having difficulty storing radio stations into 7 thru to 12 using the buttons on the unit. The instructions say to tap twice on 1 thru 6 holding on the second tap to store desired stations. Maybe it's me but it doesn't work using the buttons on the main unit but it does work using the remote buttons.
Has anyone else had the same problem or is it something I'm doing wrong when pressing the buttons?
Thanks
fmw posts on January 01, 2008 09:22
I agree with Stratman. One Wave radio was more than I ever thought the market needed. I never listen to music in bed and I haven't used an alarm clock in the past 25 years. To me it is a solution looking for a problem. Since the Wave radio has been successful, however, not everyone feels like I do.
muellerguy posts on January 01, 2008 08:41
Yes it was a JVC FS 7000 and yes the cd lid on mine also needed assistance, the odd time, to open. I've been told that was a common problem.The cd player eventually failed and the unit developed a few other problems so I sold it as is on Ebay . Then my search began for a replacement so after an extensive search and reading reviews I purchased the Boston.
Since my last post I've had a few more days to explore and test out the Boston and I must admit it's impressive. The display dimmer problem is actually working out to be a plus for me since it allows me to manually set the display bright or dim. Since it's in a bedroom it's kept always dimmed. The sound quality is stunning and I'm presently running a cd changer and double cassette player through it.
Being able to detach the speaker grills is a nice feature to allow cleaning the dust off the speakers if needed.
Of course I'm still waiting for a reply from BA USA addressing the issues I've stated in my previous post. The Canadian BA distributor has been very quick with replies and helpful plus they let me speak to their tech who told me how to perform an easy to do systems check and reset.I would suggest that BA owners find out how to perform these before returning it or having it serviced.
My present opinion is the JVC was better in certain regards but I'm becoming more and more attached to the BA and what it can do so the verdict is still out which one's the best.
Seth=L posts on December 30, 2007 13:10
muellerguy;349586
It sounds good but not as good as a JVC FX7000 micro system I previously owned.
You mean the JVC FS-7000?
Those systems are very nice, I really liked mine. Unfortunately it had a few of its own problems. The mechanical CD drawer had some issues getting open and required I help it up most of the time.
muellerguy posts on December 30, 2007 12:49
Retailing at $600 cad I expected much more. New out the box mine was defective. The auto display dimmer doesn't work. Boston Acoustics(I called them) tells me some of the latest units have this defect so mine isn't the unusual lemon. Where's quality control? For this money every unit should perform 100%. Also the Aux 3 and Headphone jack line levels are so low I have to crank the volume to 50 in order to have acceptable volume.I'm waiting to hear from a tech to see if this also a defect or can be adjusted.
No toll free # for BA and online support hasn't yet responded to my questions.
I was given a 30 day trial period plus a hefty price discount/refund after I told the dealer I bought it from about the dimmer problem but I'm still not convinced it's worth keeping.I have 27days to decide.
Polk Audio's microsystem appears to be a better buy with more features though it's $100 more.
The pros....it's not cheap looking, good compact size , great bass and I like the function buttons on both the unit and remote. The cds I've tried all play without problems and the aux 1& 2 inputs work well. FM stations are easily received even with the supplied wire antenna.
Despite the problems it's still a very high quality unit which I'd recommend to those who need a compact unit and are fussy about sound .
