You are here: Home Pro Reviews Furniture Speaker and Display Mounts & Accessories Auton 1001-LCD Motorized Projector Lift
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Tim Johnson last modified July 02, 2009
  • Product Name: 1001-LCD Motorized Projector Lift
  • Manufacturer: Auton
  • Performance Rating: StarStarStarStarStar
  • Value Rating: StarStarStar
  • Review Date: July 02, 2009 08:28
  • MSRP: $ 2849
Specifications
  • Welded Steel Construction for Maximum Strength
  • Smooth Rack & Pinion Operation
  • Optional Controllers for this Model:
  • Radio Remote (S4P-RF)
  • Infrared Remote (S4P-IR)
  • Low Voltage/Dry Contact Control (LV56)
  • Momentary Rocker Switch (RS-3MO)
  • Maintain Rocker Switch (RS-3MA)
  • Current Sensor (S4P-CS)
  • 26 x 24 x 16 (L x W x H)
  • 100 lbs. Max load
  • Adjustable height setting
  • Very convenient
  • Aesthetically appealing
  • Sturdy construction
  • Fully adjustable
  • Cool Factor
  • Expensive
  • Heavy
Introduction
You've already purchased your front projection system and all your components, and now you're left with a daunting task. How do you mount the projector, without hearing an earful from your significant other; or in this case, in a conference room with a commercial drop-ceiling? Many mounts and stands can be not-so-appealing to the female eye, such as a pole dropping from the ceiling, a stand behind the couch, or a box sitting on the conference room table. You ask yourself: does visual perfection really have to come at such a price?
Recent Forum Posts:
mtrycrafts posts on July 03, 2009 20:41
So.... a sleek streamlined projector was a no-no... but a huge wooden crate attached to the ceiling was acceptable? I will never understand some women.
Yep, some don't have an attic to place that monstrosity up in or the space between the ceiling joists between floors
Clint DeBoer posts on July 02, 2009 22:19
mtrycrafts posts on July 02, 2009 20:48
ned;590585
mtrycrafts, what is your model ?
Boy, you made me dig through all that paper, manuals, etc
It is a Draper Aerolift50, load lift to 50lbs. The projector is about 42lbs.
This box extends 15.5" down from the ceiling in the closed position.
I think this lift can drop 42" but best to check them on line
Oh, and it was about $2300 not that long ago.
ned posts on July 02, 2009 20:30
mtrycrafts posts on July 02, 2009 18:49
admin;590319
Not sure how that would fit in a residence unless there are other models
Forgot what I paid for mine but a bit of woodworking will tilt the scale to that WAF
