Atdec Visidec VF-AT-NBC Dual Laptop Monitor Mount Review
- Product Name: Visidec VF-AT-NBC Dual Laptop Monitor Mount
- Manufacturer: Atdec
- Performance Rating:
- Value Rating:
- Review Date: January 25, 2011 17:05
- MSRP: $ 229
- Specifications
Max Weight, monitor arm (lbs): 17.5
Max Weight, notebook tray (lbs): 17.5 (notebooks up to 17" in size)
Mounting Hole Pattern, monitor arm (mm): 75x75; 100x100 (optional AC-AP-2010 adaptor plate allows for 200x100)
Notebook tray tilt/pan: 35° up of forward tilt; pan: 180°
Rotation around pole, both arms: 360°
Monitor arm tilt/pan: 70° up and 70° down; pan: 180°; portrait to landscape rotation
Pole height (inches): 17.3
Cable management: Internal / Integrated
Mounting options: Desk clamp & bolt through included
Maximum reach, monitor arm (inches): 16.25
Pole diameter: 1.5
Color: Silver pole with polished arm, black notebook tray
- Easy installation
- Great articulation
- Great aesthetics
- Integrated wire management
- Versatile - holds up to 17.5lbs per arm
- VESA 75/100 compatible
- Cable management a tad wimpy
- Expensive
Introduction
