Atdec Telehook TH-1040-VFM Display Mount Review
- Product Name: Telehook TH-1040-VFM Display Mount
- Manufacturer: Atdec
- Performance Rating:
- Value Rating:
- Review Date: April 29, 2010 20:30
- MSRP: $ 99.99
- Specifications
Offers a full range of movement via three pivot points
Designed for simple installation
Quick release mechanism for fast TV attachment/removal
Ball joint allows infinite TV adjustment for any viewing angle up to 40°. Simple tension adjustment
Portrait to landscape rotation
Supports VESA mounting hole configurations: 100mm x 100mm (4" x 4"), 200mm x 100mm (8" x 4"), 200mm x 200mm (8" x 8")
Supports displays up to 25kgs (55lbs)
TV tilt adjustment +20°/-5°
TV horizontal adjustment of -/+5°
Maximum reach from wall 444mm (17½")
Minimum distance from wall 102mm (4")
Advanced internal cable management
Theft resistant design
Masonry and timber stud wall mounting hardware included
- Easy installation
- Great articulation
- Great aesthetics
- Integrated wire management
- Versatile - holds up to 55lbs, VESA 100/200 compatible
- Single connection point
- Closest to the wall it can retract is 5"
- Expensive
Introduction
show the mount attached to a flat panel set? They should have
provided 6 different jpegs that show the tv in six different orientations.
I wonder what the product manager was thinking. Based on just a picture of the mount, I will NOT be a customer.... This was poorly prepared.
How many women would buy a dress without seeing worn by a real
actual women?
