StudioTech DP-2 Flat Panel TV Stand Review
by Clint DeBoer last modified August 17, 2008
StudioTech DP-2 RW AV stand
  • Product Name: DP-2 Flat Panel TV Stand
  • Manufacturer: StudioTech
  • Review Date: December 03, 2006 19:00
  • MSRP: $ 499 ($549 w/optional pillars)
Specifications
Height: 19.5 inches
Width: 47 inches
Depth: 22.75 inches
Shelf spacing (bottom to top): 8-inch / 6-inch
Usable shelf width: 37 inches
Usable shelf depth: 18-19 inches (adjustable)
Max. weight (total): 300 lbs
Max. weight (top shelf): 250 lbs
Recommended weight (per glass shelf): 100 lbs (distributed)
Recommended weight (display on pillars): 150 lbs
Number of casters: 4
Shipping weight: 105 lbs (multiple boxes)
  • Priced to compete well with mass market electronic store options
  • Deep (adjustable to 19-inch depth) shelving for easy access to components
  • Excellent flat panel mounting option through the use of pillars and a wall-mounting bracket.
  • Veneer is always susceptible to scratches
Introduction
When you get that piece of upgraded equipment you’ve always wanted there’s typically that follow-up feeling of “man that makes my old furniture look really bad!” StudioTech is no stranger to Audioholics, and we were able to take a closer look at their DP-2 line of AV component racks. This stand works well in a corner, but also looks great when placed against a flat wall. When we took a quick peek at the specs it surprised us in that it seemed to be very “roomy” for equipment but maintained a low profile that didn’t dominate the room.
