You are here: Home Pro Reviews Furniture Racks & Stands Sanus System CFA56 AV Cabinet Review
by Tom Andry last modified April 13, 2009
  • Product Name: CFA56 AV Cabinet
  • Manufacturer: Sanus System
  • Value Rating: StarStarStarhalf-star
  • Review Date: March 20, 2009 14:30
  • MSRP: $ 849.99
Specifications
Product Width:
23.25" / 59.06 cm
Product Height:
56" / 142.24 cm
Product Depth:
23.25" / 59.06 cm
Top Shelf Width:
23.25" / 59.055 cm
Top Shelf Depth:
23.25" / 59.055 cm
Top Shelf Capacity:
40 lb / 18.18 kg
Middle Shelf Width:
19" / 48.26 cm
Middle Shelf Depth:
19" / 48.26 cm
Middle Shelf Capacity:
50 lb / 22.73 kg
Bottom Shelf Width:
19" / 48.26 cm
Bottom Shelf Depth:
19" / 48.26 cm
Bottom Shelf Capacity:
75 lb / 34.09 kg
Package Width
58" / 147.32 cm
Package Height
9" / 22.86 cm
Package Depth
25" / 63.5 cm
  • Heavy and solid
  • Easy to run wires
  • Bottom exit of wires makes placing near wall easy
  • Open architecture circulates air silently
  • Best in class removable panel for full access to gear
  • No easy way to move to get behind to access gear
  • Top and door need dampening
  • Some fit and finish issues
Introduction
The Sanus System CFA56 is quite a substantial piece of furniture. You definitely will feel like you got your $850 out of it. It is heavy, has built in "convection-style" cooling, easy access to your gear from the removable back panel, and bottom exit of wires. It is easily put together by a single person though it is not the easiest piece of furniture you'll ever assemble. The aesthetics are very good with a fairly high quality vinyl wrap over some quality pieces of MDF.
Recent Forum Posts:
