You are here: Home Pro Reviews Furniture Racks & Stands Diamond Case Theater Tech TT-400 Credenza Review TT-400 Build Quality and Optional Equipment
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Tom Andry last modified February 12, 2007
clip_image002_319.jpgOnce I got the unit flipped over and out of the box, I stood back and took a good long look at it. In a word, the TT-400 Credenza is gorgeous. The clean lines and simple accents allow the beauty of the wood and the finish to shine. The skirt around the bottom of the unit completely hides the wheels and in a longer pile carpet (like mine) you'd have a hard time convincing anyone that it is movable. And it does move. Easily. The casters roll very well - even in my carpet, fully loaded, with 150+ pounds of plasma and base on top. Be careful when moving those flat screens though. They want to tip.
The weight of the unit ensures stability even though the wheels don't lock. I didn't ever worry that it might fly across the room if my kid ran into it. On a hardwood floor, I might feel differently. While I was transporting all the components from my beloved hand made (by me) rack to the TT-400, inevitably, a stray power cord or wire would work its way out of my hand and hit the top or side of the unit. The finish was resistant enough that even close inspection reveal zero nicks. This is not to suggest that the unit is impervious to harm, but it does seem fairly resistant to minor contact.
Speaking of the top of the unit, did I mention it was thick? You can see from the pictures the top of the doors. One would think that when you opened the door you'd find the top a bit hollow. Not so. The top of the door indicated the true thickness of the top. I measured it at over 2 inches! According to Diamond Case, they specifically engineered a double top design for Theater-Tech (all of which is tongue and grooved and glued together) to provide the ultimate amount of strength for the design. All the wood front and back was finished completely. Something you rarely see in mass produced furniture nowadays. The attention to detail doesn' t stop there as all the wood is A-1 or Select Grade panel for the best possible grain patterns. Personally, I loved getting close to this piece as my appreciation for the attention to detail only increased. Anyone who has shopped for furniture of any kind has had the experience of seeing a piece across the showroom and thinking that it looked nice. Unfortunately, upon closer inspection flaws and imperfections are easily identified. With the TT-400, the only thing closer inspection brought was a sense of the love and care that went into the piece. The fact that the doors were finished completely on both sides and the inside was completely black to help hide wires and such only confirmed the attention to detail. If you want to see unfinished wood on this unit, you will literally have to pick the unit up and turn it over (see the picture of the caster above).
The only damage I saw on the unit from transport was inside one of the doors where the shelf had scored the edge. You could not see it from outside the unit and it was only semi-noticeable with the door open. This really highlighted the difference between a stained hardwood and a veneer. A veneer would have ripped or torn while the stained hardwood just dented.
Set Up and Usability
clip_image004_178.jpgUnlike this new wave of Ikea inspired FiB (Furniture in a Box) home theater equipment, the only "set up" this unit required was wiping off the wheels, flipping it over, removing the box, wiping it down, and installing the shelves. The back of the unit is secured with six screws. The screws thread into inset metal receptacles so there is no fear that repeated removal will harm the unit in any way. The rear of the unit sits off the back about an inch. This allows wire to pass through at nearly any point. The upside is that there is no need to thread your wires through wire tracks that may or may not be the right size or in a convenient location. It also makes it easier to follow the path of a wire. Once you remove the back, everything is laid bare. You can see everything.
The metal shelf pins are tipped with a concave piece of rubber that literally suctions itself to the shelf. The pins were already installed in predetermined places. Of course, I decided that I wanted a few shelves moved. That proved to be harder than I expected. It took pliers to remove the pins and a hammer to reinstall them. While it is theoretically possible to do this with your bare hands (I did one before I gave up) I wouldn't recommend it. The upside is that once installed, you can feel secure knowing that a room full of subwoofers won't shake those pins out of their holes.
clip_image006_133.jpgThe middle shelf was 1 inch black MDF while the equipment shelves were perforated metal. I really liked the idea of the perforated metal as it increased airflow (as did the semi-open back). The metal shelves were very light and easy to work with. They seemed very strong and I wouldn't have a problem putting most components on them. I might think twice about one of those boat anchor amps or a flagship receiver. Honestly, equipment that heavy tends to be quite large and would probably end up sitting on the bottom of the unit anyhow. The only downside of the metal shelves was that they tended to vibrate if left empty. If you are not going to use one of these shelves, I would suggest removing it from the unit. Better yet, issue it as the perfect reason to add a new piece to your home theater!
The two side doors had windows and the center had a black screen. Both were framed in wood and held in place by rotating plastic tabs. The glass frame was dampened with tiny pieces of foam that were only visible from the back. This should reduce the chance noisy subwoofer induced vibrations. Both were easily removable if they needed to be replaced. Personally, I LIKE seeing my equipment. Maybe that is just me. There is also an option for solid wood doors. Diamond Case will install an IR repeater system if you choose to go this route. The black screen was completely opaque unless you had a component inside. Then you could barely make out that there was a display lit up, but you couldn't read it (you also couldn't control it with an IR remote). I installed my center channel in there as well as a Sony DVD player (the reasons for this are numerous but cable length was also a major factor). The black screen is thicker than most and feels like it would resist the casual contact one with pets (like dogs or kids) could expect. One thing to think about is the location of the IR receiver on your components when choosing a location within the unit. On the bottom shelf, the wood frame around the glass/screen may block low set IR receivers.
From the back, wiring the system was as hard as you made it. The unit's open architecture is extremely forgiving. Basically, when you take the back of the unit off, all the shelves are open to you. You don't need to run wires between the shelves through channels or specific points because the screws that connect the back to the unit are all on the edge. The blacked-out interior makes the rats nest you conceal behind the removable back generally invisible. The depth of the unit is enough to accommodate most components with room to spare. I used that room to house extra wire lengths or additional wiring that I know I'll need in the future. The space behind the center channel is especially useful (and plentiful). All that extra cabling that ran from shelf to shelf was rolled up and secured there.
clip_image012_047.jpgThe media shelf is easy to set up and held a fair number of DVDs (I got 58 in there). It felt secure and sturdy. On the right side of the unit where the media shelf was housed I also had an additional shelf for a component. This necessitated the need for a window (or an IR repeater). While I liked looking at the pretty glowing lights of my components, I didn't really like looking at the back of the DVDs. My suggestion to the potential buyer is to either house your media outside the unit or opt for either the solid wood or black screen option.
The directions clearly state to test your equipment before you install the back panel. Please, please, PLEASE do this. I didn't - well I did, but then I connected a few more things and didn't re-check. I already had it in place and then had to move it back out - twice. I don't want talk about it.
Optional Equipment
clip_image014_034.jpgMy unit came with two optional "pro" features, an automated micro lighting system and an automated ventilation system. Other optional features not included but offered are an IR repeater system (for control of components behind solid wood doors) and a surge protection system, The ventilation system consisted of twin whisper fans in a push-pull configuration. For those of us with equipment that runs hot, this is a must have. The open architecture of the rear of the unit encourages air circulation but that may not be enough. Diamond Case suggests plugging these fans into the back of your receiver so that they are only activated when the receiver is on. In my case, I left them on all the time as one of my components is a HTPC that is always on. I didn't want it to overheat. At the highest setting, the fans were mostly audible from about 10 feet during normal playback. I had to turn them down to their lowest setting and even then they were noticeable at very low volumes (between songs). I could probably get away with 25% power but I'd hear them during the quietest scenes and between songs. And that would bug me.
Author's Note: Even if you spring for the optional ventilation system, you should still keep a close watch on your gear at first. Experiment with different fan settings and speeds and test to see how hot your equipment gets. Most equipment will shut down if it overheats but you can never be too careful.
clip_image016_024.jpgThe optional lighting system is, in my opinion, just too cool. Diamond Case supplied me with an appliance module that basically uses the electrical wiring in your house to transmit a signal to turn on and off the lights. The keypad can be used manually (in needs to be plugged in) or it serves as an IR receiver. Diamond Case also supplied a universal remote that can be programmed to control the lights. You can program any universal or learning remote to control the lights as well. All you would do is set up the keypad someplace near the front of the room (near, but not in the unit - it won't work in the unit) and you are good to go. I plugged the keypad in behind my seat and just reached back to turn on and off the lights whenever I felt like it. My son still doesn't understand how it works (Daddy is magic).
All the wiring in the optional equipment is tucked out of the way with black wire tracks. One of the wire tracks had fallen in transport and was hanging loose. One side of the wire track was sticky so I reinstalled the wire and stuck it back in place. I was skeptical but so far it has held.
