You are here: Home Pro Reviews Digital Media Servers VidaBox SLIM Media Center Review Karaoke, Control, TV and Summary of Test Results
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Tom Andry last modified December 08, 2006
If you opt for the Karaoke package, there are a couple of things you need to know. First, the Karaoke add-on is quite large. Luckily, it is RF capable so you can hide it away. You’ll need to connect the VidaBox Slim to your receiver via analogue cables as well as SPDIF because the Karaoke won’t send the microphone input over a digital connection. This is a limitation of the hardware and not a failing on VidaBox’s part. More than likely, this means you’ll have to disable your digital in on your receiver each time you wish to sing along (or, better yet, simply configure a different “Karaoke” input on your receiver). Since this is a party type of function, I don’t really see a problem with this. If you have a universal remote, you can program a macro to do all that for you. You’ll also need to enable the green mic in (directions are provided by VidaBox). Last, you’ll probably want to go into your audio menu and bump up the mic volume (if you open the audio options and don’t see mic in, open the Properties to enable it). At first, I thought it wasn’t working because you could barely hear the vocals over the music. Apparently, VidaBox assumes that you’ll use the mic in on the side of the unit instead of the back (which I was using). They routinely bump up the mic volume for the side input for you. They’ve told me that they will now increase the volume for both inputs.
Slim_Kar1 Slim_Kar2
One of the things I like about the MCE interface is that you can set the unit to display the closed captioning during muting. I like it so much that I’ve programmed my TX-1000 Medius remote to control the volume on the receiver but use the mute function on the HTPC.
Keyboard Comparison
I’ve had the (dis)pleasure of using both of the two main keyboards for MCE machines. Other products use a keyboard that was specifically designed for MCE while VidaBox went with a more general purpose wireless keyboard. I’ve already reviewed the MCE-specific keyboard in a prior review review so I won’t go into specifics here. The keyboard VidaBox went with is basically your standard keyboard with a number of hotkeys up top for accessing email and such (not that useful when controlling MCE) and a trackball. Personally, I much preferred the trackball over the craptacular joystick on the MCE-specific keyboard. The trackball was much easier to use and was quite responsive. Below, I’ve listed some of the advantages and disadvantages of each of the keyboard options:
Slim_Keyboard
VidaBox all purpose wireless keyboard
Slim_MCEkeyboard
MCE-specific
keyboard
  • RF control means line of sight not necessary
  • Hotkeys all but useless
  • Trackball easy to use but can get dirty and unresponsive
  • Small size fits well on lap
  • No backlighting
  • IR control means you’ll need line of sight
  • Hotkeys for most all MCE functions
  • Joystick literally painful to use but won’t ever get any less responsive (isn’t all that responsive to begin with)
  • Larger size makes accessing navigation buttons easy
  • Some backlighting
>There is really no clear winner here in my book. Personally, I like the all purpose keyboard provided by VidaBox a bit better because of the RF and trackball but that is purely a personal preference. With the MCE keyboard, you can easily control each and every function of MCE, with the all purpose keyboard, if you aren’t navigating Windows, you should stick with the remote. As I generally only use the keyboard when navigating Windows, I find the trackball much more useful over Satan’s joystick.
Remote
As I’ve already reviewed the MCE remote previously, I just wanted to add here that I came across a problem with the remote that needs to be mentioned. It seems that this remote has an issue if the buttons are continually pressed for too long a period of time (read: you sit on the remote). Basically, the remote seizes up and refuses to respond. I’ve read a number of solutions but the easiest is just to remove the batteries for 30 minutes or so. This seems to clear out the capacitors (or whatever the problem is, I’ve read a lot of speculation) and the remote will return to normal functioning. Or, you can get a universal and throw the darn thing away.
TV
The VidaBox Slim comes with a Cable signal splitter. At first I thought this meant that they had two dual tuners. I was wrong. Conversations with Vidabox indicated that they believed that the single tuner cards they use in their box to be of higher quality that the dual tuner cards that split the signal within the card. I can’t stress enough the convenience of the DVI out. While component is fine, DVI is far superior. If for no other reason, you can choose your output resolution pretty precisely. I was able to output 1360x768 (which is the native resolution of the Olevia 542i display I was using during the time of this review).What does this really mean? 1:1 pixel mapping baby! You absolutely can’t get a better picture out of this box. Even standard definition analogue cable looks pretty good. But how good?
Perfect Score is 130
VidaBox Slim (Standard Configuration) Benchmark Score: 56
Test
Max Points
DVI 1360x768
DVI Pass/Fail
Color Bar
10
10
Pass
Jaggies #1
5
3
Pass
Jaggies #2
5
3
Pass
Flag
10
5
Pass
Detail
10
10
Pass
Noise
10
0
Fail
Motion Adaptive NR
10
0
Fail
Film Detail
10
0
Fail
Cadence 2:2 Video
5
0
Fail
Cadence 2:2:2:4 DV Cam
5
0
Fail
Cadence 2:3:3:2 DV Cam
5
0
Fail
Cadence 3:2:3:2:2 Vari-speed
5
0
Fail
Cadence 5:5 Animation
5
5
Pass
Cadence 6:4 Animation
5
0
Fail
Cadence 8:7 animation
5
5
Pass
Cadence 3:2 24fps film
5
5
Pass
Scrolling Horizontal
10
5
Pass
Scrolling Rolling
10
5
Pass
Total Points
130
56
Comments of HQV Testing
The VidaBox scored well on just about everything that’s critical except for the noise reduction and film detail tests. My subjective experience is that it takes standard definition analogue cable and manages to make it look good on very large screens. Moiré is a problem (as indicated by the failed Film Detail test) and it would be nice if the unit reduced noise, but overall you’re going to be very pleased with the picture out of the Slim.
