You are here: Home Pro Reviews Digital Media Servers VidaBox SLIM Media Center Review
by Tom Andry last modified October 18, 2006
  • Product Name: SLIM Media Center
  • Manufacturer: VidaBox
  • Review Date: October 18, 2006 20:00
  • MSRP: $ 2499 ($2966 as tested)
Specifications
Video Outputs:
Standard - VGA, DVI-I
TV Out - S-Video, composite, component (HD)
Video Resolution:
800 x 600, 1024 x 768, up to 1920x1444
EDTV - 480p
HDTV - 720p, 1080i, (1080P Limited Edition)
Audio: Onboard ALC880 chipset 7.1 surround sound:
(6) rear 3.5mm ports
(2) Side 3.5mm ports (mic, headphone)
(1) coaxial SPDIF output (rear)
Optical Drive: Combination full size CD/DVD burner (dual layer capable)
Read speeds: CD - 48X; DVD - 16X
CD write speeds: CD-R 48X; CD-RW 32X
DVD write speeds: DVD±R 16X; DVD+RW 8X; DVD-RW 6X; DVD+R DL 8X; DVD-R DL 6X
Data Storage: 500GB VidaSafe™ standard; up to 1,500GB VidaSafe™ optional
Memory: 1GB (2x 512MB) 800MHz DDR2 non-ECC (standard)
HD Audio:
7.1 channel high definition audio
Digital SPDIF coaxial output
Side Ports:
(1) Headphone jack
(1) Microphone jack
(1) IEEE-1394 6-pin firewire port
Front I/O Ports : (4) USB 2.0 ports
Noise Level: Rated at less than 27 dBA at 1m (nominal)
Power: 100 - 240V 60Hz AC
Dimensions: 16 11/16” (W) x 4 1/16” (H) x 16 15/16” (D)
TV Tuner Specs & Input Ports:
Dual standard definition NTSC TV tuners with advanced video noise-reduction filters for crystal clear picture quality.
Tuner connections:
·  (2) Coaxial analog cable inputs
·  (2) FM antenna ports
·  (2) Composite video inputs
·  (2) S-Video inputs
·  (2) L/R RCA audio inputs
Rear I/O Ports:
(4) USB 2.0 ports
(1) PS/2 keyboard input
(1) 6-Pin firewire (IEEE-1394) port
(1) PS/2 mouse input
(1) VGA (15-pin) monitor port
(1) DVI-I monitor port
(1) 10/100/1000 ethernet port
(1) TV-out port, S-Video, Composite, YPbPr
(3) Audio ports
(2) FM tuner input ports (coaxial)
(1) SPDIF coaxial output port
(2) analog cable tuner coaxial input ports
(2) AV tuner input ports
(1) Parallel port
Software:
·  Windows Media Center Edition 2005.
·  "My Movies" media center add-in - backup, catalog and watch your DVD collection.
·  "My Weather" media center add-in - Check your local weather and forecast within media center.
·  nVidia Purevideo decoder - bronze edition.
·  Media Center DVD burning software to create DVD's playable in standard DVD players (most other media center systems do not have this software).
·  Karaoke / CD+G software
Included Accessories
Microsoft remote control
Microsoft infrared receiver with (2) infrared blaster for set-top box control
2.4GHz RF wireless keyboard with integrated trackball
(2) FM antennas
Cable splitter with (2) short jumper coaxial cables
(2) S-Video/Composite/RCA audio dongle for TV tuner
TV-out breakout dongle
External 7-in-1 USB card reader
Optional Accessories:
802.11g USB wireless adapter
Logitech Harmony® universal programmable remote control
Karaoke kit #1- (2) wireless mikes, (1) mike mixer, and 400 songs
Karaoke kit #2- (2) wireless mikes, (1) mike mixer, and 900 songs
  • Great aesthetics
  • Relatively stable
  • Great audio and video output
  • Great customer service
  • Lack of configuration options
  • Loud fan
  • Undimmable lights on the front
Introduction
When I was contacted by Steven Cheung, one of the co-founders of VidaBox, about reviewing one of their units, I was less than thrilled. I’d already reviewed a machine running MCE (Microsoft Media Center Edition) so I didn’t see what the big deal could be. But as I browsed their site and looked a little closer, I saw some unexpected things. First, there was a media center the size of a shoebox. Second, there was one that looked like a DVD player. But mostly what I noticed was the severe lack of configurations available. Wait a second, I thought, aren’t these just PCs? Aren’t they able to be configured however you want? It seems that VidaBox has taken a different tact. Rather than letting the user slap together whatever accessories and options they want and hope that everything meshes together the way it should, they pre-configure the system and test it extensively to make sure it is stable and solid out of the box. Supposedly, these means that once you set up the system, it should need little to no maintenance. No unexpected crashes, no driver conflicts, just solid performance. You know, the kind of performance you’d expect from a DVD player or a receiver. Well, we’ll just see about that.
