You are here: Home Pro Reviews Digital Media Servers Slim Devices Transporter Digital Music Player Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified March 06, 2007
  • Product Name: Transporter
  • Manufacturer: Logitech Slim Devices
  • Performance Rating: StarStarStarStarStar
  • Value Rating: StarStarStarhalf-star
  • Review Date: March 06, 2007 10:07
  • MSRP: $ 1,999
Specifications
DAC: AKM AK4396 Multi-bit Sigma-Delta D/A, 120dB Dynamic Range, 120dB SNR (A-weighted), -106dB THD+N
Digital Outputs: 15 picoseconds intrinsic jitter (std. deviation), coax, optical, BNC S/PDIF, & balanced AES/EBU
Digital Inputs: Coax, optical and BNC S/PDIF, and balanced AES/EBU inputs can be used to drive the DAC, network streaming or pass-through
Word Clock Input: Allows synchronization to an external clock source
Display: Dual 320x32 grayscale vacuum florescent displays with multiple text, spectrum analyzer and VU views
CPU: 325MIPS 8-way multithreaded, 8MB audio buffer & SlimDSP
Network: True 802.11g wireless, 10/100mbs Ethernet
Decoders: WAV, AIFF, MP3, WMA, FLAC with 24 bit resolution, 44.1, 48 and 96k sample rates
Communications: TCP/IP control, infrared input, infrared output, RS-232
Rack-mount Brackets: Optional
Finish: aircraft grade aluminum cases available with choice of black or clear anodized finishes
Weight: 6kg (13lbs)
Power: Autoranging linear power supply 100-240v, 50-60Hz, 10W
Remote Control: Custom, backlit, 32-key infrared remote
Dimensions: 17”W x 3”H x 12.25”D (433mm x 72mm x 311mm)
Warranty: One year parts and labor; 30-day Satisfaction Guarantee
  • Well-designed chassis that blends well with esoteric high end gear
  • Cool "force-feedback" TransNav control knob
  • Excellent 802.11g wireless range
  • Digital coax and optical S/PDIF inputs/outputs
  • Wireless bridge option
  • Rhapsody Music Service Support
  • SqueezeNetwork allows use without PC
  • Almost universally compatible with most operating systems
  • Expensive for casual consumers (who alternatively can get a Squeezebox)
  • No direct "digital" input control on remote
Introduction
I hate CD players. They're bulky and they typically play only 1-5 discs at a time - unless you get a CD changer and that's like getting the family pack at Krystal - it isn't about quality. We're no strangers to Slim Devices Digital Network Music Players. In fact, we've reviewed both the second and third iterations of the Squeezebox Digital Music Players. This product is more than I would have expected - or even hoped for - a completely tricked-out Squeezebox with dual displays, upgraded DAC, and enough functionality to serve as the true powerhouse in any "analogue-is-my-friend" system. But can this new "Cadillac" model really replace your CD player?
