You are here: Home Pro Reviews Digital Media Servers Impact Acoustics Multi-Function Converter with Tuner and Picture in Picture Review
by Tom Andry last modified June 06, 2007
  • Product Name: Multi-Function Converter
  • Manufacturer: Impact Acoustics
  • Performance Rating: StarStarStarhalf-star
  • Value Rating: StarStarStarhalf-star
  • Review Date: June 06, 2007 14:07
  • MSRP: $ 119
Specifications
  • Converts S-Video or composite video to VGA
  • 181 channel cable ready tuner
  • Display home theater sources, gaming systems and camcorders on your flat panel
  • Use in a school dorm to turn a standard PC monitor into a television
  • MTS stereo output for a complete theater experience
  • Output resolution up to 1024 X 768 for 24 bit RGB true color
  • Plug-n-Play, no software required
  • Completely cool
  • Totally convenient
  • Not at all reliant on MCE or Vista (yea!)
  • Small and unobtrusive
  • Terrible remote
  • Picture in Picture a little small
  • Can’t switch audio on the fly
  • No digital cable or cable card support
  • PC volume affected by the TV volume even when the unit is off
Introduction
The first thing I thought when I saw the Impact Acoustics Multi-Function Converter with Tuner and Picture-in-Picture was, “Wow, that’s a mouth full!” I knew two things, first, that I had no idea what it was and what it did, and two, that there had to be a better name. Well, I now know what it is but I can’t say I’ve come up with a better name. In short the MFCwT&PnP (I don’t think that acronym is going to catch on) stands between your computer and your display. When activated, it mutes the volume from your computer, overlays a TV signal on your display, and sends the audio to your speakers. But how well does it work?
Recent Forum Posts:
