You are here: Home Pro Reviews Cables & Switchers WireTracks WT-RF-01-10 Wire Management System Review
by ray last modified December 21, 2005
WireTracks Wire Management System
  • Product Name: WT-RF-01-10 Wire Management System
  • Manufacturer: WireTracks
  • Performance Rating: StarStarStarhalf-star
  • Review Date: December 21, 2005 19:00
  • MSRP: $ 199.50
Specifications
  • WT-RF-01-10  (10 each 8 ft pieces)
  • 8 ft long, 2.5 inches wide, 0.5 inches thick
  • White paintable surface
  • Also available in 5 ft pieces
  • Cost effective alternative for pre-wiring home theater
  • Relatively easy to install
  • Paintable surface
  • Large enough to accommodate all wiring needs
  • Factory end cuts not square
  • Plain rectangular styling
  • No inside or outside corners
Introduction
A recent upstart company, Wire Tracks, located in the great Pacific Northwest has introduced a unique product that can help the average home theater DIY'er pre-wire their home theater easily and cost effectively. The Wire Tracks kit can be installed behind existing baseboard or surface mounted. There is also a kit for crown molding installation. The wires are neatly hidden within the plastic molding in a large chamber.
