You are here: Home Pro Reviews Cables & Switchers PureLink HDS-41R 4x1 HDMI Switcher Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified December 07, 2006
PureLink HDMI Switcher
  • Product Name: HDS-41R 4x1 HDMI Switcher
  • Manufacturer: PureLink
  • Value Rating: StarStarStarhalf-star
  • Review Date: December 07, 2006 11:48
  • MSRP: $ 549
Specifications
Features
  • Easy switching between two (or four) digital video sources using remote control or the switch button on the switch
  • LED Indicators
  • Low cost solution for home theater integration
  • Plug-and-play - No software installation - Installs in minutes
  • Built-in RS-232 port
  • HDCP Compliant
Frequency Bandwidth: 1.65 Gbps (single link)
Video Resolutions: Supports up to 1080p HDTV / 1920x1200 at 60Hz(WUXGA)
Inputs: Two HDMI Female ports on the HDS-21R and four HDMI Female ports on the HDS-41R
Output: One HDMI Female port both the HDS-21R and the HDS-41R
Power supply adapter: DC 5V, 2A Power supply adapter (Included)
Remote control: IR Remote Control Unit (Included)
HDS-41R Weight / Dimensions: 3 lbs / 10x15x2 inches (WxLxH)
HDS-21R Weight / Dimensions: 2 lbs / 9x10x2 inches (WxLxH)
  • Easy installation
  • Flawless switching (full 1.65Gbps HD support)
  • Passes HDCP-encoded signals and 1080p
  • Remote has discrete input switching (programs well into universal remote macros)
  • Solves cable-box-HDMI-to-receiver issue
  • RS-232C support for AMX, Crestron, etc
  • Flimsy ‘Select’ button on unit
  • Target pricing is geared towards custom installers
Introduction
HDMI is sweeping the electronics industry by storm and, not surprisingly, many manufacturers are not keeping up with the demands. On one hand you can get an HDMI-switching receiver, but you’ll likely have to pay $1000 or more to do so. While this might be a cool upgrade, it really may not be something you want to rush out and buy – especially if you just bought a receiver last year that has all the latest DSP and trimmings, save the digital video support. For those people an HDMI switcher may just be the ticket
