You are here: Home Pro Reviews Cables & Switchers Planet Waves DIY Home Theater Cable Making Kits Planet Waves DIY Cable Kit Conclusion
by Gene DellaSala last modified April 24, 2008
Recommendations
spaghettiAll of the Planet Waves cables are intelligent solutions for the consumer DIY and Custom Installer based marketplaces. The 6 leaf connectors for the COAX cable make excellent contact with component equipment, as do the other terminations (ie. F, BNC, female RCA). Since these cables target DIY and Custom Installers, and are an ideal solution for installation beyond the sheet rock barrier, it was a good call to get CL2 approval from a safety concern. The Planet Waves COAX cable solutions are well-suited for consumer audio and HD video applications. The main benefits of using a 24AWG solution here are costs, and ease of termination and insertion to already existing drywall.
However, if this cable is intended to be used for HD applications (720p or higher resolution) and/or SDI pro video transmission over long runs (greater than 50ft) such as the tests previously conducted, I would advise considering an alternative Coax cable of 18AWG and ensure the supplier can guarantee the characteristic impedance of the cable within 75Ω +- 2Ω to minimize return loss issues which can surface as ghosting and/or ringing in the video signal. In most applications such as 480i/p outputs of DVD players or set top boxes, this won’t be an issue.
The Planet Waves DIY Home Theater Kit proved to be a versatile product for the end user and custom installer alike. It’s probably the easiest self terminating system I have come across and the fact that you can pretty much utilize any conceivable analog termination on the market with a simple twist on connector and fastening screw is something every home theater aficionado and cable installer should have in their bag of tricks. While it didn’t score very high on value, it topped the charts for convenience and ease of use. I requested that Planet Waves should sell the cable and connectors in bulk to allow consumers to buy as much as they need. This should help provide better value to the end user.
Peering the Planet Waves website, I didn’t detect any snake oil literature pimping the wonders of this product so that scores a lot of points in my book since the product and company is snake oil free. This is a solid product that will work in virtually any installation (used within the guidelines of this review) requiring a precise cable length and termination. If you are looking to shorten your cable lengths behind your rack to reduce the cable spaghetti, and want a simple solution that even your grandmother could use, I highly recommend the Planet Waves DIY Home Theater family of products.
Planet Waves
http://planetwaves.com/
D'Addario & CO Inc
595 Smith St.
Farmingdale, NY 11735
Phone: 631-439-3300
Test Equipment List
  • · Modified Liteon LVD-2001 DVD upconverting player 480i NTSC and Pal 480p 720p 1080i
  • · JVC GD 723 DVD player 480i,480p
  • · Denon DVD-5910 Player 480p for Component, 1080i for HDMI/DVI
  • · Yamaha RXV-2700 receiver
  • · Denon AVR-5805mkii receiver
  • · Sony VPL 400Q LCD projector
  • · Hitachi 70 VS 810 LCD
  • · Sharp XV-Z200U DLP
  • · Syntax Olevia LT-30HV 30” LCD Display
  • · Sony KP-51WS500 51” HDTV RPTV
  • · Phillips HD-30" Direct View
  • · High Definition Box from DISH Network
  • · Standard Digital DVOM
  • · Wayne Kerr 6420 Impedance/Magnetic Analyzer
  • · Audio Precision SYS2722 Audio Analyzer
  • · RBH Sound Signature T-30LSE Loudspeaker System
  • · RBH Sound 66-LSE Signature speakers with Status Acoustics Upgrade
  • · Axiom Audio EP500 Subwoofer
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
PerformanceStarStarStarStar
VersatilityStarStarStarStarStar
Build QualityStarStarStarStar
Ease of Setup/Programming/IntegrationStarStarStarStarStar
FeaturesStarStarStarStarStar
ValueStarStarStar
Buy Now
gene posts on April 24, 2008 17:26
My response is: Bluejeanscables.com
While I am huge fan of Bluejeans cable, the average end user cannot self terminate their own cables and you need expensive crimping tools and know how to do the job right with 1694 and canare connectors.
tn001d posts on April 24, 2008 15:39
