You are here: Home Pro Reviews Cables & Switchers Monoprice Component & S/PDIF Digital Coax/Optical Toslink Audio to HDMI Converter Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Tom Andry last modified July 15, 2009
Monoprice Component & S/PDIF Digital Coax/Optical Toslink Audio to HDMI Converter (whew! now there
Monoprice Component & S/PDIF Digital Coax/Optical Toslink Audio to HDMI Converter (whew! now there's a mouthful)
  • Product Name: Component & S/PDIF Digital Coax/Optical Toslink Audio to HDMI Converter
  • Manufacturer: Monoprice
  • Performance Rating: StarStarStar
  • Review Date: July 15, 2009 03:20
  • MSRP: $ 37.20/each (less if you buy in bulk)
Specifications
Input Video Signal: 1.2V p-p
Input DDC Signal: 5 V p-p (TTL)
Output Video: HDMI 1.2 + HDCP 1.0/1.1
HDMI Connector: Type A (19 pin) female.
Video Connector: 3 RCA Component
Audio Connector: 1 RCA Digital Coax / 1 Digital Optical Toslink
HDMI Video Amplifier Bandwidth: 1.65Gbps/165Mhz
Frequency: Up to 165Mhz
Supported Resolutions: 480i thru 1080p
Size: 91mm (w) x 22mm (h) x 75mm (d)
Shipping Weight: 0.12 Kgs
Operating Temperature: 0 degree C to 70 degrees C.
Operating Humidity: 10% to 85% RH (no condensation)
Storage Temperature: -10 degrees C to 80 degrees C.
Storage Humidity: 5% to 90% RH (no condensation)
External Power Supply: 5V DC @ 2A
Regulatory Approvals: FCC, CE UL
  • Price
  • Easy Setup
  • Occasional Video Distortion
Introduction
With changing technology, people often come up with problems that require very specialized solutions. If you need a product like the Monoprice Component & S/PDIF Digital Coax/Optical Toslink Audio to HDMI Converter, you really need it. While the unit isn't without its quirks, it does perform (mostly) as advertised. If you're tired of having to switch inputs on your display but don't want to upgrade your TV/receiver, the Component & S/PDIF Digital Coax/Optical Toslink Audio to HDMI Converter might be just what you're looking for.
Recent Forum Posts:
meballard posts on July 22, 2009 11:24
GlocksRock;600173
So how does a HDMI to component device deal with HDCP?
Purely from a technology perspective, it's not that difficult. If something can be displayed on a TV, it can be converted to another format.
GlocksRock posts on July 22, 2009 07:35
meballard posts on July 21, 2009 18:20
That only converts from component to HDMI. HDMI to component does exist, but it's quite a bit more expensive (but Monoprice does carry it).
I've found the devices to be quite useful myself. Originally to convert from a Component switch to HDMI and not need to run the larger component cables. Later to simplify my system and get rid of the need for switches (I have enough input on my Yamaha receiver, but not enough component inputs, so I used 2 of these and now I have enough inputs), and all switching is handled by my receiver, plus a reduction of cable clutter (short multi piece cables to the converter, then a single HDMI to the receiver).
DEIMOS280 posts on July 18, 2009 21:21
Will this work to hook up a ps3 (hdmi out) to the converter, then run component to your tv and still do 1080p?? or will it only convert component TO hdmi?
cwall99 posts on July 17, 2009 09:53
Clearly a niche product.
