You are here: Home Pro Reviews Cables & Switchers Impact Acoustics SonicWave Speaker Cable Review
by Gene DellaSala last modified January 21, 2008
SonicWave speaker cables
  • Product Name: SonicWave Speaker Cables
  • Manufacturer: Impact Acoustics
  • Review Date: October 04, 2006 20:00
  • MSRP: $ 109 (12' terminated)
Specifications
  • Maximum performance through advanced cable design, construction and materials
  • Multiple connector configurations for the most common high-end speaker applications; 5/16in Spade Terminals and Banana Plugs
  • 24K Gold-Plated Terminals
  • Oxygen-free copper ensures maximum fidelity.
  • Ideal for Home Theater and music applications.
  • Packaged individually so you can customize to your unique installation
  • 10AWG oxygen-free copper is constructed from 7 bundles of 18AWG conductors
  • Snake oil free, no nonsense cables
  • Excellent all inclusive and interchangeable terminations
  • Great build quality
  • Obtrusive plastic block on each end of cable
Introduction
While the debate rages on with the "Cable Experts" or those whom I usually refer to as "Cable Soothsayers", its nice to know Impact Acoustics is on the same mission as Audioholics' a "no BS" approach while delivering the best products and/or services.
