You are here: Home Pro Reviews Cables & Switchers GefenTV Wireless HDMI Extender 5 GHz Review GefenTV Wireless HDMI - Is Wireless HD Possible?
by marshal last modified June 18, 2009
GefenTV Sender and receiver Can you dig this? I hooked up a wireless, high-definition transmitter and was watching HD movies and TV in less than 15 minutes. If you're surprised, imagine how I felt. I had approached reviewing this GefenTV Wireless HDMI Extender 5Ghz with extreme cynicism; after all I've seen plenty of these devices demoed at Consumer Electronics Shows. First there'd be the elation - wow, no wires! Then the exclamation - wow, you mean I can really just hook up my Blu-ray player or Dish HD satellite Receiver and send up-to-1080p/24 frames per second video over to my front projector or HDTV some 100 feet away? But then there'd be the dejection - what do you mean, it's been delayed again? That this GefenTV is actually shipping doesn't remove any of the questions except the last, but at least that means I can try it out in the "real-world" and not at some trade event or controlled setting.
So there I was, holding the lightweight and slightly larger than a paperback book-sized Sender in one hand and the Receiver in the other. At $900 for the set, it isn't cheap, but more important is whether it can actually do the job. And for that to happen, that meant no video freezing up or blanking out. Or any hiss stuttering or loss of audio either (although that's a lot easier to get right than video). Which brings me to one of the key issues that has been holding back other companies from bringing devices like this out: interference. The technology that's doing the heavy lifting has to not just perform, but perform consistently in an environment that's filled with EMI (electromagnetic interference). As in coming from wireless networks, cell phones, microwaves, cordless phones, you name it. And add on all this coming from neighbors as well for apartment dwellers.
GefenTV uses wireless 802.11n to do its thing and operates in the unlicensed 5 GHz band to transmit HDTV. The tech folks at Gefen say that this is a dependable technology, compared to all the hoopla of using lasers and so-called futuristic choices. And I'm also told that the technology is robust enough to deal with issues like EMI. We'll see.
Recent Forum Posts:
morrone posts on June 22, 2009 17:34
"To begin, nothing on the units indicate which is which, but it's pretty obvious which is the Sender and which the Receiver once you look at the connections on back. The Sender has a HDMI output and a plug for power, while the Receiver has a HDMI input, plug for power as well as left/right analog audio outputs (note: this output is only active when the audio being carried along by the HDMI source is 2 channel LPCM)."
I think you have that backwards; the Sender has the HDMI input, and the Receiver has the HDMI output. Which kind of calls into question how "obvious" it is.
