You are here: Home Pro Reviews Amplifiers Sherbourn 7/1250A Amplifier Review
by Gene DellaSala last modified February 13, 2005
  • Product Name: 7/1250A 7-channel Amplifier
  • Manufacturer: Sherbourn Technologies
  • Review Date: February 13, 2005 19:00
  • MSRP: $ 2000
Specifications
Continuous Power Output: 125 wpc (20Hz-20kHz) All channels driven
Speaker Impedance: 4-ohms, minimum
SNR: Input Impedance/Sensitivity: 104dBa (full power) / 40 kohms
Power Requirements: 115V, 60Hz (US); 230V, 50Hz (European)
Dimensions: 17.7" x 18.2" x 7" (WxDxH)
Weight: 62 lbs
  • More power than stated
  • Reasonably lightweight
  • Runs cool
  • Can sound bright on some speakers
  • Slight hiss at low volumes
Introduction
Sherbourn is no stranger to this design concept, as we learned when reviewing their venerable 5/1500A and 7/2100 multi-channel amplifiers. Their previous amps were true mono block designs with completely independent power supplies for each channel. Unfortunately these amps weighed over 100lbs, making installations a bit of a challenge and transportation even more so. In order to get the size, weight and price down, Sherbourn designed a slightly less powerful version of its big brother 7/2100A, but with dual power supplies to feed all of the seven channels.
