You are here: Home Pro Reviews Amplifiers Marantz PM-11S1 Integrated Amplifier Review
by Clint DeBoer last modified June 15, 2007
Contributors: Gene DellaSala
  • Product Name: PM-11S1 Reference Integrated Amplifier
  • Manufacturer: Marantz
  • Performance Rating: StarStarStarStarStar
  • Value Rating: StarStarStarhalf-star
  • Review Date: June 15, 2007 00:00
  • MSRP: $ 4399
Specifications
Continuous Power Output: 100 wpc x 2 (20Hz-20kHz, 8-ohms) Both channels driven, continuous
THD: < 0.01% (20Hz – 20kHz, 8-ohms
Input Sensitivity/Impdance: 240mV/20k
Frequency Response: 5Hz – 120kHz (+/-3dB)
Speaker Impedance:
4-ohms, minimum
Inputs: 1 balanced XLR, 6 unbalanced RCA (1 phono)
SNR: 96dB (CD, Line)
Bridged Mono Mode: Can Bi-amp
Transformer Type: toroidal
Control: RS-232C, D-Bus Remote (RC-5) In/Out (to sync multiple units)
Power Requirements: 115V, 60Hz; 380W consumption
Dimensions: 17 5/16” (W) x 6 1/2” (H) x 17 1/2” (D)
Weight: 57.2 lbs (26 kg)
  • Best-in-Class Performance
  • Elegant look and feel
  • Balanced inputs
  • Superb chassis and component shielding
  • Hi-end binding posts
  • Stereo and Bi-amp mode
  • Preamp outputs for expandability
  • Far exceeds its power spec
  • Not inexpensive
  • No DACs - analogue inputs only
  • Remote not backlit
Introduction
I drive a simple vehicle. It's a 2003 Jeep Liberty and I like it a lot. If I were offered the opportunity, however, to test drive a Hummer or Porsche Carrera - I'd do it in a heartbeat. Why? Because I'm not likely to fork out that kind of money in my lifetime and it's occasionally nice to see "how the other guy lives". The Marantz PM-11S1 is my Porsche Carrera this month. At a price tag of over $4k I'm not going to be able to afford to keep this baby in my reference system for long, but it is a superb machine with all the styling of a European sports car. It's the kind of product you don't want to leave fingerprints on and will find yourself taking extra time to install it into your system - not because it can't be manhandled or take the abuse, but because - like a fine work of art - you don't want to diminish its beauty in any way.
Recent Forum Posts:
cosmin.batica posts on July 08, 2011 06:44
I always admired Marantz gears. I listen to PM-11S1 and it's indeed a very good amplifier.
But I recently own the PM-15 model (the original one - 1994, not current PM-15S1 or PM-15S2 model) and I must say it's a truly high-end masterpiece. Far better than any of other integrated that Marantz ever made.
cornelius posts on June 23, 2007 08:34
Great review! Thanks!
I liked the amp comparison, really helps appreciate the quality of a great piece of gear.
mattburk posts on June 22, 2007 21:52
So, moderator. what would you pick: 1. Parasound jc-2 and mono blocks or 2. Marantz ma-9s2 & SC-7s2.
mattburk posts on June 19, 2007 23:01
great read. I have been eyeing the high end marantz gear for a while but I have yet to see a review. I hope you review there separates next & compare them with the likes of classe, parasound, plinius and ps audio.
