You are here: Home Pro Reviews Amplifiers Emotiva Reference Theater Series IPS-1 Amplifier Review Reference Theater Series IPS-1 Conclusion
by Gene DellaSala last modified May 31, 2007
IPS-1top.jpgThe Emotiva IPS-1 7CH amplifier has proven to be a solid performer. It’s a cool running amplifier that doesn’t need a great deal of ventilation under most operating conditions, making it ideal for shelf or rack installations. This amplifier can be utilized with moderately efficient 8- or 4-ohm speakers and will likely drive them with more composure and grace than comparably priced receivers and certainly as good as any dedicated multi-channel amplifier in this price class. In fact, one of its closest competitors, its own big brother the MPS-1, is very similar in design to the IPS-1 but has more power and completely independent card based modules and sells for mere $500 more, but I actually think I prefer the cheaper, less powerful IPS-1! The IPS-1 is in a more manageable form factor making it easier to transport and setup. The IPS-1 has about a 2dB lower noise floor than the MPS-1 thanks to the absence of a limiter circuit. You can also beat the snot out of it without fear of the amplifier shutting down. I felt both amplifiers sounded much LARGER than they measured or their price tag indicated and believe either unit would serve as an excellent power center for all but the largest scale home theater installations.
I felt the IPS-1 sounded much larger than it measured....
From its excellent sonic characteristics, to its no-nonsense build quality, fit and finish, Emotiva has once again demonstrated via the IPS-1 that you don’t have to break the bank to get quality electronics that rival many of the more well known brands at a fraction of the cost. If you’re looking for a solid sub-$2k multi-channel amplifier for bi-amplifying your stereo speakers, or for powering your sophisticated 7.1 channel home theater that won’t falter on tough power demands, save $800 bucks and buy the Emotiva IPS-1. Your ears and your wallet with certainly thank you.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Frequency Response LinearityStarStarStarStarStar
SNRStarStarStarStar
Output ImpedanceStarStarStarStarStar
Measured Power (8-ohms)StarStarStarStar
Measured Power (4-ohms)StarStarStarStar
Multi-channel Audio PerformanceStarStarStarStar
FeaturesStarStarStarStar
ValueStarStarStarStarStar
Buy Now
Recent Forum Posts:
gene posts on May 03, 2007 10:15
Great review Gene. I would have thought that the noise floor would have been higher with the lack of the isolated card design of the MPS 1.
I know you are not easily impressed, so your preference of this model over the MPS1 says something.
Nice job
The IPS-1 still has independent mono block amps just like the MPS-1 but you can't slide the modules in and out. The MPS-1 would have identical SNR if you pull the limiter circuit off which is easy to do. Emotiva will instruct customers on request if you wish to do so.
I mostly prefer the IPS-1 b/c its more manageable and easier to setup.
westcott posts on May 03, 2007 09:01
Nice job!
Gov posts on May 02, 2007 19:12
Great review!!! I wish the LPA-1 review Audioholics did was as in depth as this one. I would love to see how the LPA-1 stacks up against this amp.
