You are here: Home Pro Reviews Acoustical Products Auralex MoPADs Monitor Isolation Review Auralex MoPADs Setup, Listening Tests and Conclusion
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Gene DellaSala last modified July 25, 2009
The MoPADs come in two pairs per package (four individual units) which can serve a pair of normal sized (under 1cu^ft) bookshelf speakers or one center channel speaker mounted horizontally. The MoPAD base is about 1 inch thick, 12 inches deep, 4 inches wide and with the use of their wedge adjustor pads (included in the kit) provisions for variable pitch of your speakers between -8, -4, 0, +4 and +8 degrees. Since I obviously needed to pitch my speakers downward, I oriented the wedge adjustor pad so that the speakers would fire at a pitch of 8 degrees downward. For those installing a center channel on a floor or stand under a projection screen, pitching the speaker upward would be most useful. I intend on taking full advantage of this once I get my primary reference system up and running.
My reference bookshelf speakers are a relatively small profile design (8 inches wide) the exact width of two MoPADs placed together - making for a perfect fit.
My center channel required a pair of MoPAD kits spaced out about 3.5 inches.
At this point, I was ready to dig into some listening tests. Listening tests you say? Has the Prez of Audioholics turned to the dark side of esoteric audio? I certainly hope not. While I initially wasn't expecting any sonic miracles from this tweak, I did find it intriguing to determine if I thought I could subjectively hear a difference in my setup.
Disclaimer to the Objectivists: Red Alert Red Alert!
This is by no means a scientifically controlled DBT. I am fully aware that audio memory can play tricks on the mind but I found little reason to bring out the big guns in this review since the focus of this product was really to help properly position the speakers and decouple them from the surface they are to be placed upon. At such a contest the MoPADs delivered exactly as promised.
Listening Tests
I've been spending a lot of time lately listening to the fabulous recorded demo disc from AIX records. Recordings like this really help drive my point home about the Dumbing Down of Audio and the complacent tolerance most consumers have towards low fidelity, highly compressed media. Recordings like those found on this disc truly make your playback system live up to its full potential. Before installing the MoPADs, the surround experience on this disc was nothing short of stunning. The bass was pronounced and the instruments sounded real and uncompressed. After the MoPAD installation, I felt as if the vocals from the front soundstage became more focused and the upper mid bass sounded even tighter and more defined. The pitch downward from the MoPADs allowed for a more uniform dispersion of the front three speakers showering the listening area with a more direct sound experience and bringing me closer to the performance rather than reflections and refractions caused by poor speaker placement and the room. I couldn't help but to give my speakers more juice because for the first time since I installed them above the entertainment center, they seemed to be properly imaging. The nasally characteristic caused by interaction between the entertainment center and the speakers and inadequate pitch towards the listener I had heard before seemed to be significantly reduced. Lowen and Navarro's "Cold Outside" sounded absolutely stunning. The vocals came across as dynamic and airy, while the instruments were clearly defined and well placed within the listening space.
Shameless Plug for AIX Records: We've finally found a producer and recording/mix engineer that knows how multi channel audio should sound. Now if they could only ramp up with record deals from more popularly known jazz and rock artists we'd be good to go.
Recommendations
If you've got no choice but to install your speakers on top of an entertainment center or a poorly inert stand or shelf, this is the "must have" product to decouple your speakers and eliminate resultant sound colorations caused by nasty resonances. The variable pitch capability of these isolator pads is very useful for speaker installations that aren't at or near ear level. The only minor gripe I had was that the MoPADs themselves are about 1.25" in height towards the front of the speaker, which will of course raise an already elevated speaker even higher. Overall, this is a small price to pay for sound isolation and properly pitching your speakers to the listening position.
While we still have compelling world issues to deal with, at least we can rest safely knowing there are companies making product to better the sound of our systems. The Auralex MoPADs isolation devices are worth their price of admission and are highly recommended!
Auralex MoPADs
MSRP: $39.95 / 2 pair
www.auralexelite.com
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Build QualityStarStarStarStar
Ease of Setup/Programming/IntegrationStarStarStarStarStar
PerformanceStarStarStarStarStar
ValueStarStarStarStarhalf-star
Buy Now
