You are here: Home Pro Reviews Acoustical Products Auralex MoPADs Monitor Isolation Review
by Gene DellaSala last modified November 03, 2009
Auralex MoPADs
Auralex MoPADs
  • Product Name: MoPADs Monitor Isolation Pads
  • Manufacturer: Auralex
  • Performance Rating: StarStarStarStarStar
  • Review Date: May 06, 2006 20:00
  • MSRP: $ 39.95 (2 pair)
Specifications
  • 5 position wedge adjusters (+4,+8,0,-4,-8) degrees
  • Dimensions: 12" long x 4" wide
  • Weight Limitations: 100lbs.
  • Does fantastic job of decoupling speakers
  • Variable pitch for wide installation options
  • Improves fidelity of poorly installed speakers
  • Raises speaker 1.25"
  • Not available in alternative colors
Introduction
In an ideal world there would be no war, disease or hunger and our loudspeakers would be perfectly placed in perfect rooms for perfect sound. While Auralex probably can’t help resolve world issues, they certainly can help with speaker placement, room acoustics and isolation as evident by their isolation pad devices they refer to as MoPADs and the up and coming new acoustically treated room for the Audioholics Showcase home premier reference system.
