Pro Audio Technology Intros In-wall, In-ceiling, and Subwoofer Products
Building on the success of its initial high-output in-wall loudspeakers, Pro Audio Technology (PRO) has expanded its offering of designer-friendly products to include new in-wall, in-ceiling and subwoofer models. Featuring professional components and DSP optimization, the new models bring PRO’s unique high-output performance to a lower price point than previously available. The SCRS-5iw in-wall loudspeaker joins a 3/4-inch compression driver to a PRO-designed elliptical horn for broad dispersion of high frequency energy. Its 5-inch woofer employs a powerful ferrite magnet with an oversized voice-coil, resulting in a high-sensitivity design capable of output levels of 110dB and a dynamic range typically associated with larger floor standing loudspeakers. Measuring only 3 7/8-inch deep, the SCRS-5iw installs easily in a standard 2 x 4 stud bay.
The SCRS-25iw ceiling loudspeaker integrates the drivers of the SCRS-5iw in a dual woofer configuration providing greater sensitivity and higher maximum output level of approximately 115dB. Functionality is enhanced by an angled baffle design - ideal for applications where directing sound toward a specific listening position is desirable. The all-metal construction provides robust build-quality commensurate with the product’s bulletproof performance and includes a back-box that easily fits between 12-inch on-center joists.
To compliment their full-range speakers, PRO is introducing two new subwoofers. The LFC-12im features a highly specialized 12-inch woofer in a shallow enclosure engineered for easy retrofit installation in a traditional 2 x 4 stud bay. A powerful neodymium motor and huge 5-inch voice-coil deliver deep, tuneful bass at output levels belying the LFC-12im’s unobtrusive size (115dB max output). For more demanding applications, PRO’s new LFC-14sm high-impact floor-standing subwoofer employs a proprietary long throw 15-inch driver housed in a compact enclosure. A black textured paint finish is standard. Wood veneer is available at an up-charge.
Each product is engineered for simple retrofit installation, requiring only minutes to install and all in-wall and in-ceiling models come with a bezel-less, paintable metal grille. Like other PRO products, the new loudspeaker models are designed for bi-amp operation using the company’s DSP-driven digital amplifier technology to maximize performance. Passive (single amp) operation will also be available.
For further information please visit www.proaudiotechnology.com.
About Pro Audio Technology
PRO was founded upon a simple principle: Combine preeminent engineering technology from consumer and professional audio fields to produce the most accurate, robust and aurally-exciting audio products available for installed residential systems. Pro Audio Technology, formerly known as PHC (Professional Home Cinema) was renamed in 2010.
