You are here: Home News & Opinion Trade Show Coverage 2004 Consumer Electronics Show (CES) Earthquake Sound Amps and Subwoofers
by Clint DeBoer last modified May 31, 2007
Filed under: Receivers, Processors, and Amps
Once again, while we were running, or jogging, between meetings, we happened upon a company called Earthquake Sound (Hohmann Internation). Perhaps what captured our attention and made us notice, was their attractive products.
Earthquake Sound New Speaker - No Model Number provided for the Speaker or Girl :-)
We didn't get a chance to audition these gems, but they sure were fun to look at. The speakers are somewhat reminiscent of a pair of famous speakers from Britain, no?
In addition to a broad range of home audio speakers, Earthquake Sound also provides 3-channel and 5-channel amplifiers, such as the Cinenova Grande 3 and Cinenova Grande 5 both seen here.
Cinenova Grande 5 and Cinenova Grande 3
Cinenova Grande Grande 5 Retail - $4,449
  • Number of channels: Five discrete monaural blocks.
  • Power rating per channel :
    (8-ohm load), all channels driven: 300 watts.
    Freq . Response (@ 1 W w / ± 0.1dB: 20 Hz to 20 kHz.
  • Channel separation: greater than 95 dB.
  • Max . input voltage: 1.9 volts.
  • Input impedance: 27,000 ohms.
  • Total harmonic distortion -THD:
    1 kHz, 8-ohm load: 0.001%.
    20 kHz, 8-ohm load: 0.003%.
  • Signal to noise ratio:
    @ 1 kHz, 112 dB.
    @ 5 kHz, 111 dB.
  • High-pass / low pass variable filter , range 20 Hz to 5 kHz (one/ channel).
  • High-pass/Full range/Low pass operation via 3-way switches (one switch per channel).
  • Dimensions: 9.25" x 18" x 21" ( H x W x D ).
  • Gross Weight : 141 lbs .
Cinenova Grande Grande 3 Retail - $3,449
  • Number of channels: Three discrete monaural blocks.
    1 kHz, 4-ohm load: 0.003%.
    @ 1 kHz, 112 dB.
    @ 5 kHz, 111 dB.
  • Gross Weight : 119 lbs .
But Earthquake Sound is more than just a speaker and amplifier manufacturer. They also have a range of different Subwoofers, including the new Supernova MK-V seen here.
Supernova MK-V Subwoofer Retail - $5,400
  • Burl finish
  • One Magma-15 active driver
  • One SLAPS-15 passive radiator
  • One BA212 - 580 watts digital amp
  • Multi-position remote sensor & control
  • Dimension 19"x19 x19"
  • Weight 74 lbs
At the same display booth, we also perused through Earthquake Sounds large variety of Car Audio speakers. Looks like they have some quality products to offer. We hope to review some of them this year.
