You are here: Home News & Opinion Trade Show Coverage 2004 CEDIA Expo Energy Act System, S8.3, S10.3 and S12.3 Subwoofers
by Gene DellaSala last modified May 31, 2007
Filed under: Loudspeakers
Energy's latest line of subwoofers pictured from left to right (S8.3, 10.3, 12.3) all feature their new patented Ribbed Elliptical Surround which is said to increase performance by eliminating surround distortion. The computer designed ribs are said to eliminate any surround deformation, a common problem with high output subwoofers.
Act Sub
S8.3
S10.3
S12.3
System Type
Bass Reflex with downward firing woofer and front port
Bass reflex with downward firing port
Bass reflex with downward firing ports
Amplifier
80wrms / 300watt dynamic
100wrms / 400watts dynamic
200wrms / 800watts dynamic
300wrms / 1200 watts dynamic
Woofer
8" injection molded
8" poly ceramic hybrid
10" poly ceramic hybrid
12" poly ceramic hybrid
Max Excursion
1.49" pk-pk
1.57" pk-pk
1.61" pk-pk
Frequency Response (+-3dB)
30-120Hz
27-120Hz
21-120Hz
19-120Hz
Variable Phase
+-180 deg
+- 180 deg
+- 180 deg
Variable LPF
50-120Hz 18dB/Oct
50Hz - 110Hz 18dB/Oct
Inputs
RCA/SPK
RCA/SPK
RCA/SPK
RCA/SPK
Crossover Filter
Active/bypass
Active/bypass
Active/bypass
Power Switch
Off/Audio/On
Off/Audio/On
Off/Audio/On
Off/Audio/On
Dimensions
16.25"x10"x14"
16.4"x11"x14.25"
17.25"x14.13"x18.4"
19.25"x16.5"18.4"
Cabinet Weight
24lbs
25lbs
34lbs
47lbs
Retail
$800 with 5 Act1s
$350
$500
$800
Finish Options
Shadow silver
Black ash or Shadow Silver
Black ash or Maple / Shadow Silver
Black ash
[Picture_011] [Picture_012]
The Energy Act6 system may be small in size, but certainly not in performance. For under $800 you get five (5) Act1 satellite speakers each containing a ¾" aluminum dome tweeter and 3 ½" micro filled polypropylene woofer and the Act subwoofer. Also pictured to the right is the Energy Take SAT ($175/ea) and LCR ($250/ea) ideal for on-wall placement installations.
