You are here: Home News & Opinion Press Releases Sanus Announces 3 New Wall Mounts for Flat Panel TVs
by Clint DeBoer last modified July 16, 2006
St. Paul, Minnesota - Sanus Systems introduced its three new VisionMount™ Wall mounts for flat panel TVs. This first product - Model ML22 -is perfect in installations where medium LCD flat panel TVs must be firmly, yet unobtrusively mounted flush against the wall in living rooms, bedrooms, bathrooms and kitchens. Model ML22 features universal mounting brackets fitting virtually all 15" to 40" flat panel TVs, including mounting patterns VESA 50, VESA 75, VESA 100, VESA 200 and VESA 400 x 200. It is easy to install and is packaged with all necessary mounting hardware.
Model ML22 is constructed of heavy-gauge steel that supports up to 100 lbs. It comes in two durable, powder-coated finishes: silver (ML22-S1) and black (ML22- B1). This product includes a wide wall plate allowing consumers to match a larger array of TVs. Additionally, on the wall plate there are two square cutouts for easy in-wall cable access. It also contains a redesigned latch system for securing the TV brackets to the wall plate. The latch can accommodate a padlock for added security. This model's mounted size is 14.5"h x 10.75"w x 1.0"d. It is currently available and lists for $89.99 US, $109.99 Canadian.
  Sanus also introduced its new VisionMount™ Tilting Wall Mount for medium LCD flat panel TVs. This mount - Model MT25 - is perfect for consumers where tilting ability of flat panel TVs is as important as a low profile installation. It comes in two durable, powder-coated finishes - silver (MT25-S1) and black (MT25-B1) - and looks great in installations where the mount is visible from the side of the TV. This mount is excellent for use in living rooms, bedrooms, bathrooms and kitchens.
Model MT25 features Sanus Systems' patent-pending Virtual Axis™ tilting technology that provides smooth, balanced tilt motion up to ±20° with fingertip ease. This product includes a wide wall plate allowing consumers to match a larger array of TVs. It comes with two universal mounting brackets fitting virtually all 15" to 40" flat panel TVs, including mounting patterns VESA 50, VESA 75, VESA 100, VESA 200 and VESA 400 x 200. Additionally, on the wall plate there are two square cutouts for easy in-wall cable access. Model MT25 also has a special locking system to lock TV securely to the wall for added safety and security. The product is easy to install and is packaged with all necessary mounting hardware. This mount is constructed of heavy-gauge steel that supports up to 100 lbs. This model's mounted size is 14.5"h x 11.25"w x 2.38"d. It is currently available and lists for $109.99 US, $129.99 Canadian.
[MF110] Finally, Sanus Systems introduced its new VisionMount™ Full Motion Wall Mount for medium LCD flat panel TVs. This mount, Model MF110, is designed for applications where full motion - tilt, swivel, pan and extend functions - of LCD TVs is important. This feature allows consumers to extend the TV from the wall up to 9.5" and swivel and tilt it for best viewing. It comes in two durable, powder-coated finishes - silver (MF110-S1) and black (MF110-B1) - and looks great in installations where the mount is visible from the side of the TV. This mount is excellent for use in living rooms, bedrooms, bathrooms and kitchens.
Model MF110 features Sanus Systems' patent-pending Virtual Axis™ tilting technology that provides smooth, balanced tilt motion from +5° to -15° with fingertip ease. This mount also has a special locking system to lock TV securely to the wall for added safety and security.
It comes with a mounting plate fitting virtually all 15" to 40" LCD TVs, including VESA 100, VESA 200 and VESA 200 X 200 mounting patterns. It is easy to install and is packaged with all necessary mounting hardware. This mount is constructed of heavy-gauge steel that supports up to 100 lbs. This model's mounted size is 13.5"h x 12.25"w x (2.5"-9.5")d. It is currently available and lists for $199.99 US, $249.99 Canadian.
Sanus Systems designs and builds a broad variety of audio video furnishings, mounts and accessories that will satisfy even the most demanding audio/video enthusiast or interior designer. Every Sanus product is engineered to enhance both the A/V system and the surrounding décor. Today Sanus offers over 300 products, including home theater units, TV stands, audio racks, wall mounts and speaker supports. Sanus products are available at thousands of retail locations nationwide; a store locator is available at www.sanus.com .
