You are here: Home News & Opinion Press Releases Impact Acoustics Announces New VGA270™ HD15 UXGA Monitor Cables
by Gene DellaSala last modified December 14, 2006
Impact Acoustics, an innovative leader in computer connectivity products, proudly announces its new line of VGA270™ HD15 UXGA Monitor Cables. Featuring patent-pending connectors that rotate 270°, these cables are ideal for connecting video equipment such as projectors, video splitters, monitors, and KVMs when installation flexibility is critical.
VGA270 cables bring the ultimate flexibility to video applications and installations by featuring patent-pending HD15 connectors on each end that rotate 270° from side to side in almost a complete circle. The capabilities of the VGA270 technology provide the installer more options to customize cable installation by requiring less open space and allowing the cable to easily move the direction it is desired to run. The connectors feature detents, or "click-stops", at every 90° to ensure that absolute signal integrity is maintained and that the connector is not twisted beyond the 270° capability. See a visual demonstration of the VGA270 cable in action.
VGA270 HD15 UXGA Monitor Cables are constructed from three coax and four twisted pair, allowing these cables to support the highest resolution video signals available. Each connector contains oversized slotted thumbscrews that enable easy equipment connection, no matter how tight the application. Impact Acoustics offers VGA270 HD15 M/M UXGA Monitor Cables and M/F extension cables in a variety of lengths from1-50ft and connects components that utilize a standard HD15 port. Each cable is backed by a lifetime warranty against defects in workmanship. VGA270 HD15 UXGA Monitor Cables are available through Impact Acoustics distributors, resellers and online at: http://www.impactacoustics.com .
SUMMARY OF KEY FEATURES AND BENEFITS
  • Rotating 270 degree connectors on each end move from side to side in almost a complete circle
  • Ideal for very tight connection areas
  • Constructed from three coax and four twisted pair and an overall foil and braid shield to support the highest video resolutions
  • Oversized slotted thumbscrews make connecting your equipment easy
  • Ideal for connecting video presentation equipment, video splitters, monitors, and KVMs
  • HD15 M/M Cables and HD15 M/F Extension Cables available from 1-50 feet.
About Impact Acoustics:
Impact Acoustics is a division of Lastar, Inc, a leader in computer connectivity solutions since 1984. Under the brand Impact Acoustics, Lastar created a line of computer connectivity products renowned for quality and value. Impact Acoustics uses the finest components and the latest construction technologies to maximize cable performance and ensure compliance with industry specifications for each cable and its designated application. For more information regarding Impact Acoustics, visit www.impactacoustics.com .
