You are here: Home News & Opinion On-Location Articles Denon 2005 Summer Conference - S-Series Home Theater Systems
by Clint DeBoer last modified July 23, 2009
As the home theater-in-a-box market continues to grow (for example, it showed $800 million in sales this year as opposed to $450 million in sales for A/V receivers) it is apparently clear that consumers areĀ  very interested in small form factor 2-channel and home theater systems. Denon is addressing this market in full force with its new S-Series home theater pre-packaged systems.
The design targets are simple:
  • remote control that is simple, yet extensive (dual functions for "daytime" and "power" users)
  • key lighting for ease of use and function feedback
  • activity-based menu system for allowing user control over device functions in an interactive, dynamic way
  • inviting, intuitive controls
The first two systems developed by Denon in the S-Series are the S-101 and the S-301. The S-301 features an acrylic and aluminum front face, round form factor on all sides, "sexy" blue lighting accents, and an arched appearance for style and compactness.
In appearance, the S-101 differs only in color, lack of acrylic facia materials and orange illumination in lieu of blue.
The speakers are slim and designed to produce excellent sound for both movies and music. The goal was to make this a well-rounded system that outperforms, as well as out-functions the competition.
Some very notable features (a complete list and comparison chart is below):
  • The 8" subwoofer enclosure contains all amplification and connects to the main unit via a single DB25 "umbilical" (which also supplies power to the main unit). As a result, the sub module is the only component that needs to be supplied power
  • The S-301 has a perforated aluminum grill while the S-101 has a fabric grill
  • An aluminum shelf speaker stand as well as a wall bracket are included (the wall bracket stands the speaker off from the wall to a depth equal to the majority of plasma displays)
  • The speaker connector is upgradable and can be removed with an included key. Aftermarket or extended length wire can be used by installers, though speaker wire is included in the system
  • There are four (4) wires total to connect the entire system
  • The unit is designed to function under the principal of "1-key operation"
  • The S-301 includes HDMI 1.1 and SACD/DVD-Audio playback capability as well as Faroudja processing for upconversion of inputs to 480p (HDMI supports OSD, but does not upconvert composite or s-video input)
  • The S-301 essentially has a built-in DVD-2910, including AL24 processing and dual 216 MHz video DACs
  • Remote control is pre-programmed to handle all known satellite and cable TV boxes (including SA and Motorola)
  • Both units can control and pass audio and video from a connected iPod (see below)
iPod Connectivity
The S-101 and S-301 also add some incredible iPod functionality. It includes control and command of iPods through the use of a proprietary cable (included) and will put the iPod data on the screen (looks just like a full-color representation of what you would see on the iPod). The iPod will even charge while plugged into the systems. The cable does perform digital to analogue conversion - this was necessary in order to comply with Apple's DRM needs. If you use an iPod Photo you will get pictures along with any soundtrack you wish to play along with it - all through the cable. Remember, the remote control is able to control the iPod at this point - this is VERY cool. The system works with 3rd or 4th generation iPods or iPod Minis. You can simply use the mini stereo plug (included, no remote control or charging obviously) for older units.
Without any further ado... here is the full feature chart for the two units.
2005 S-Series Feature Chart
Feature
S-101
S-301
Availability
July '05
August '05
SRP
$999
$1599
Finish/Front Display and Key Lighting
Bright Silver/Orange
Dark Silver/Cool Blue
Front panel construction
Aluminum Plate
Solid Aluminum/Acrylic
Power Output; Watts per Channel into 2ch
50
70
Subwoofer Amplifier Power
100
140
Dolby Virtual Speaker Decoding
Yes
Yes
Dolby Headphone Decoding
Yes
Yes
Dolby Pro Logic II Decoding
Yes
Yes
dts Decoding
Yes
Yes
WMA9/MP3 Decoders
Yes
Yes
HDCD Decoder
Yes
AL24 Processing for Stereo/Direct Modes
Yes
Analog Devices SHARC 32-bit DSP
Yes
Yes
JPEG/Kodak/FujiFilm Photo Viewer
Yes
Yes
CD/Video CD/CD-R/RW
Yes
Yes
DVD-R/RW, +R/+RW Conditional
Yes
Yes
SACD and DVD-Audio Multi-Channel Decoder - DVS applies on top for 2.1 playback
Yes
Progressive Scan DVD Player - 480p only
Yes
Progressive Scan DVD Player featuring DCDi Engine by Faroudja FLI-2310
Yes
HDMI Output with selectable scaling - 480p/720p/1080i
Yes (1)
Video D/A Converter
Integrated 10bit/54MHz
Dual 12bit/216MHz
ADV-7314
Video Conversion to Component
Yes
Yes
Video Conversion Composite to S-Video and down
Yes
Yes
Composite Video Inputs
2
2
S-Video Inputs
2
2
Composite/S-Video/Component Outputs
1 each
1 each
Analog audio inputs
3 (including mini-jack)
Digital Inputs
1 Opt, 2 Coax
1 Opt, 2 Coax
Digital Outputs
1 Optical
1 Optical
Analog to Digital Conversion - Burr-Brown PCM-1803 (24-bit/96-kHz)
Yes
Yes
iPod Proprietary Input (Cable supplied)
Yes
Yes
USB Input for Portables/Flash Players
Yes
Analog Mini-jack input for portables
Yes
Yes
56 Station Tuner Presets
Yes
Yes
RDS - Radio Data Services
Yes
Yes
On Screen Help Menu with System Setup
Yes
Yes
Advanced Setup Option Available
Yes
Yes
DSP Controlled Boundary Gain Compensation - auto adjusts by speaker placement (On wall, shelf, etc)
Yes
Yes
Headphone Output
Yes
Yes
Night Mode
Yes
Yes
Cinema EQ - adjustable to compensate for different Room Acoustics
Yes
Yes
RS-232C Port - Third Party Control
Yes
+12v Trigger Output
Yes
Remote In/Out Ports
Yes
Preprogrammed Dual Faced Design Remote with Main Function Glo-Keys
Yes
Yes
Remote Control Dimensions (mm) Width/Height/Depth
50/233/19
50/233/19
Center Unit Dimensions (mm) Width/Height/Depth
380/97/250
380/97/250
Denon Original Speaker Cable/Connector - Cable can be upgraded
Yes
Yes
Denon Original Cable - Center Unit to Sub
Yes
Yes
Main Speaker Configuration
2 way/2 drivers
2 way/3 drivers
Mid-Bass Driver Compliment, per cabinet
3.5" x 1
3" x 2
Tweeter Compliment, per cabinet
.75" Polymide x 1
.75 Soft Dome x 1
European Design and Tuning
Yes
Yes
Main Speaker cabinet material
Metal Compound Mold
Metal Compound Mold
Main Speaker Baffle material
Mold with Fabric
Aluminum/Punched Metal
Main Speaker Magnetic Shielding
Yes
Yes
Main Speaker Frequency Response
80Hz-30kHz
80Hz-30kHz
Main Speaker Dimensions (mm) Width/Height/Depth
133/335/76
133/335/76
Subwoofer Diameter
8"
8'
Subwoofer Cabinet Material
MDF
MDF
Subwoofer Magnetic Shielding
Yes
Yes
Subwoofer Dimensions (mm) Width/Height/Depth
236/370/485
236/370/485
There is so much to say about this units. Take special note (above) of RS-232C support as well as 12V trigger output for the S-301. The S-301, in addition to iPod functionality can control a Rio or other portable USB-based players or flash devices through the inclusion of a USB port that will also charge the unit while connected. SImply connect the device and the S-301 can navigate the content with its on-screen display. The remote functions automatically control the playback of the device contents.
These pictures show you some of the compatibility and flexibility of these new systems. This home theater product is designed to go head to head with a certain name brand product that you would probably recognize. Just in terms of appearance, features, flexibility, and ease of use I believe it could stand to alter the marketshare numbers significantly.
