Griffin and Dijit's Beacon Turns Your Mobile Device into a Universal Remote
Griffin Technology partnered with software developer Dijit to turn your favorite iOS or smartphone device into a Universal Remote Control. Beacon allows fingertip control of your entire entertainment system, thanks to hardware and app integration from Griffin and Dijit. Beacon turns an iOS or smartphone device into a handy, easy-to-use remote for home entertainment systems by converting Bluetooth signals from your device to the infrared commands your components are expecting. Beacon pairs your iOS device or smartphone with Dijit's Universal Remote App, putting complete control of your home entertainment center in the palm of your hand. There are no bulky cases or dongles, no messy wires or cables.
Setup and pairing is simple. Paired with Beacon via Bluetooth, your smartphone is just a few taps away from using Dijit's intuitive Programming Guide. Your Multi-Touch or touch screen display is the remote. You can change channels, volume, input, program your DVR, and lots, lots more.
The Dijit app uses a constantly updated device code library to make setting up controls for your TV, set-top box, sound system, media players and more simple and intuitive. For components not yet included in Dijit's library, the app also includes an integrated learning feature.
Key Features
- Wireless universal audio/video controller for iOS and other smartphone platforms
- Low-profile component designed to blend unobtrusively with any decor on your coffee table
- Use your iOS or smartphone device as a powerful universal remote control, without dongles or cases
- Converts Bluetooth signals from your iOS or smartphone device to infrared signals required to control AV components
- For use with Dijit's Universal Remote app, a free download from the App Store
- No wires or power cables; runs up to two months on 4 AA batteries
Pricing and Availability
Beacon, $79.99, will be available May 2011.
About Dijit
Dijit is the only company that that provides consumers with the ability to control, discover and share their home entertainment experience, no matter where they are. Dijit's Personal Media Assistant application runs on iPhone and Android, and can be used in conjunction all cable and satellite providers as well as new content providers like Netflix, Amazon and Hulu in early 2011. Founded by entrepreneur Maksim Ioffe, Dijit is now available for download at www.dijit.com. Dijit is based in San Francisco with partners nationwide.
About Griffin Technology
Founded on Paul Griffin's kitchen table in 1992, Griffin Technology Inc., is today one of the world's foremost creators of accessories for home, mobile, and personal technology. Unique products such as iTrip®, PowerMate®, iFM®, iMic®, and Evolve® Wireless Speaker System have broken new ground in consumer electronics and created loyal fans the world over. Today, Griffin products are conceived, designed, and developed in-house and continue to push the envelope of the industry they helped create. Learn more about Griffin's entire range of ingenious designs at www.griffintechnology.com.
rnatalli;789216
IR signals don't always have to be on-axis and they also bounce off walls so unless you have a stubborn component, placing the beacon in a corner will probably work.
Does this REALLY work with everything or it there a list of compatible brands?
ratso;789089
does anyone know how this works? the round reciever, it seems i read it operates in a 360 degree range. do you need a line of site then from the reciever to the component, like you would place it somewhere in the middle of your room - i can't really picture that.
