Forum Contest - Aperion Intimus 4B Speakers with Wall Mounts!
by October 03, 2010
Aperion Audio is giving away the chance to one (1) pair of Aperion Intimus 4B Bookshelf Speakers with Mounting Brackets to one (1) eligible forum member! The speakers are available in Gloss Black or Medium Cherry (winner's choice). At $260 for the speakers and $40 for the brackets, this contest represents a $300 value! The speakers feature a 4” woven-fiberglass woofer mated with a 1” custom designed silk-dome tweeter in a curved design aesthetic and small form-factor anti-resonant cabinet with furniture-grade finish. The wall mount makes these the perfect choice for those looking to add surrounds or upgrade to a 7.1 system. All you need to do is be a registered Audioholics forum member, have USA Residence and answer the a few easy questions in the contest thread. Note this contest ends on October 31st, 2010. Winners will be drawn shortly thereafter.Have fun and good luck!
Pat D posts on October 31, 2010 17:50
Both Apple and Microsoft are making it easier for music lovers to listen to their collections by offering free music streaming services through either Windows 7 or iTunes 10. Windows 7 certified devices utilize “Play-to” and Mac is offering “Airplay”. Both allow you to push music from your computer to a connected device that is certified for the service.
1. Have you heard of either of these free services?
* NO
2. How do you currently play music from your computer on your home audio system? (Please detail your set up: Aperion Home Audio Link (HAL), Sonos, Squeezebox, Roku etc.)
I hook up the 1/8" stereo headphone output to a 1/8" splitter jack and hook that up to the preamp auxiliary input with RCA cables. I know, it's disgustingly low tech!
3. Would you be interested in a powered speaker that you could plug into any AC outlet and then play music from your personal collection via your computer without any other components?
* If yes, where you would use such a speaker (bedroom, bathroom outdoors, kitchen etc.)?
Bedroom and outdoors.
* What controls that you would expect this speaker to have (power, volume, etc.)?
Power, volume, balance.
4. Do you currently own a smart phone? (iPhone or Android device?)
Nope.
Shike posts on October 30, 2010 04:04
Yes, I've heard of airplay but have not used it.
A direct connection to my computer with my DAC playing music in FB2K. Sometimes I stream to a netbook.
Really depends on the cost and performance. May work alright for a bedroom system if the cost is reasonable with a solid way of controlling them extraneous from smart phone solutions (mine is often not supported).
Yes, but the caveat: it's a Palm.
kibbyster posts on October 28, 2010 17:17
* YES (If Yes, please explain which service and how you use it.)
* NO
NO
I use a sonos.
this would be nice. I would use it in the kitchen. power and volume
4. Do you currently own a smart phone? (iPhone or Android device?) NO
GACrabill posts on October 28, 2010 15:39
1. No.
2. I don't play music from my computer ... I am not a fan of compressed music.
3. No.
4. No.
moggi1964 posts on October 28, 2010 13:13
No
Don't, sadly.
Only if it had an interface that I could interact with to see what was playing and then to make changes to save having to go back to the main room to make changes.
Volume
Sound
Browse control
Yes; iPhone.
Submit News!
