You are here: Home AV University Frequently Asked Questions Less Equals more? Differing Volume Levels on Receivers
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Gene DellaSala last modified August 30, 2004
Q: I've been wondering about this for a while and have an idea, but no solid explanation. I own an RX-V800 receiver which as you know is rated at 100wpc. I was given a Sony STR-DB940 (110wpc) and decided to do a little comparison for the fun of it. So what I'm wondering is why does the Yamaha receiver sound louder than the Sony at the same volume level? Essentially, how does less equal more? Thanks for your time.
Audioholics: Rich, you are comparing sensitivity of volume controls between the receivers, not overall gain. Position of the volume knob is irrelevant. In addition, power ratings are not always telling the truth because each company rates power differently. Make sure when you compare power that it is for full bandwidth (20-20KHz) into 8 ohms with both channels driven.
Assuming power is rated the same between both receivers and you realize their maximum output without distortion, the difference in volume between 100 watts and 110 watts is only 0.41dB. You would need double the power to gain an extra 3dB!
Please review our previous "Equal Power or Not" FAQ.
Keep listening (safely!)
