You are here: Home AV University Frequently Asked Questions Connecting a Subwoofer to a Receiver with No Subwoofer Output
by Clint DeBoer last modified August 30, 2004
Q: Is it possible to connect a subwoofer in a Technics AV Receiver Control Receiver SA-GX350? How? It has NO subwoofer output, but has 4 Front (A + B) , 1 Center, 2 Rear speaker output and Dolby Prologic Surround Mode (it is possible to eliminate Center and choose volume for Center and Rear speakers ).
Audioholics: You may connect your subwoofer speaker level to your Receivers Speaker A output.
Run a pair of speaker wires in parallel for each connection;
One pair for the left main and left sub speaker level input;
And one wire for the right front and right sub speaker level inputs.
DO NOT USE Speaker B on your Technics Receiver as the connection is hooked in series and will degrade sound.
For more info, read the following FAQs and articles:
Enjoy the Music!
