You are here: Home AV University Display Formats & Technology Display Technologies Guide (LCD, Plasma, DLP, LCoS, D-ILA, CRT) LCD Projection or High Temperature Poly-Silicon (HTPS)
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified August 30, 2004
Technology Overview & Description
LCD_technology.gif HTPS is an active matrix transmissive LCD. It's advantage over LCDs using other systems is that it is smaller, has higher resolution and higher contrast, and can embed drivers.
A Thin Film Transistor (TFT) display is used for the light valves. Light from an ultrahigh pressure mercury (or other) lamp is split into red, green, and blue using a special mirror called a dichroic mirror, which passes light with a certain wavelength while reflecting a specific wavelength. After the image is created by LCDs for each color it is rejoined with a prism and projected. Light usability is better in a 3-Light Valve System than a 1-Light Valve System as you can achieve greater color depth and contrast. This transmission method is utilized in both LCD front projection and rear projection systems.
LCD projection technology continues to dominate the low-end projector market and was almost exclusive to the office projector market until last year. The portability and brightness of LCD projectors have made them a popular choice for portable presentations. The lightest LCD projectors weigh-in at less than 5 lbs.
What's Next
In HTPS microdisplays, the aperture ratio is defined as the ratio between the bright pixel area and the pixel area that is blocked by the transistor required to drive each pixel. The aperture ratio must be maintained in order to preserve display brightness. Due to technical difficultly of shrinking the intra-pixel transistors, HTPS pixels cannot be made smaller without lowering brightness and reducing picture quality. A lower aperture ratio worsens the pronounced "screen door effect" often seen with LCD technology. Adding more pixels without shrinking each pixel maintains the aperture ratio, resulting in an enlarged panel and added cost.
Newer LCD projectors include special optics enhancers like micro-lens array that minimize pixelization known as the "screen door effect." and have contrast ratios as high as 1500:1, though as we have found during our measurements, contrast ratio numbers are largely just marketing gimmicks (we try to provide fairly accurate "real-world" measurements on any displays we review). Look for increased contrast ratios and better black levels with higher generation LCDs. A lot of companies are behind this technology so it won't be sitting idle.
LCD Projection Advantages
  • Excellent color reproduction
  • Relatively inexpensive
  • Lightweight
  • Only 12-16" depth required for RPTVs
  • Newer units sporting better contrast levels and deeper blacks
LCD Projection Disadvantages
  • Perceived "screen door" effect common in lower cost front projectors
  • Lamp life (2000-3000 hours typical)
Sony KDF-70XBR950 LCD Rear-Projection Television (left); Yamaha DPX-500 LCD Projector (right)
