You are here: Home AV University Cables and Interconnects Long HDMI Cable Bench Tests - Monster Cable Shootout HDMI Cable Testing Results
by Clint DeBoer last modified July 23, 2009
We set up a simple grid to document our test results for the various cables submitted. Unfortunately, not every manufacturer puts out cables in identical lengths, so you'll need to interpret the results creatively, understanding that if a cable passes 4m, but fails 10m, we don't know for certain whether it would pass at 5m or 7.5m, though you can get a feel for the results after measuring a bunch of cables and seeing endless patterns and trends. This means that if one manufacturer passes at 4m, and another fails at 5m, you may be looking at identical results if the 4m cable had been extended another meter. We'll provide more analysis below.
What Do All Those Numbers Mean?
It's not as confusing as you think. We did 5 different tests, largely because the computer was already preconfigured and also because it took care of the three major tests I was interested in and added two more for good measure - one on the low end, and another on the high end. To start, we took 742.5Mbit/s per channel which tells us if a cable will pass plain old 720p or 1080i. The next step up was 1080p, which has an effective speed of 1.485Gbit/s per channel (by "per channel" we mean for each of the red, green and blue channels that carry the bulk of the information in an HDMI cable). Typically, you'll see cables and HDMI-equipped products designed to handle this type of data spec'd at 1.65 Gbps. Next up was the new 1080p at 12-bit (Deep Color). This is both significant and superfluous. Significant because HDMI 1.3-enabled products all carry HDMI chipsets that can handle data rates of 2.23Gbit/s (see this excellent article for a nice tech overview of HDMI 1.3). Superfluous because there are currently no Deep Color sources which are in any sort of practical use in home theaters today (nor are they expected in the near future, save a few HDV cams and possibly some 'as-yet-unreleased' PS3 video games). The first of the final two tests measured the ability to pass the actual maximum HDMI 1.3 spec limits (and realize the NO electronics manufacturer supports this since all current HDMI chipsets are limited to 2.23 Gbit/s speeds). This is a future-ready test.
Monster also added a fifth and final test which they described as being the equivalent (mathematically) of 1080p at 120Hz. While I seriously doubt anything except possibly a gaming system in a PC-rig will ever exceed 60Hz to a display, it's neat to see how cables collapse under a future format. Given the proclivity for HDMI Licensing to spontaneously change their spec - to the collective "Here we go again" sigh of the entire industry - this isn't entirely unreasonable for the future.
The Objective HDMI Cable Test Results
Company
720p/1080i 8-bit
742.5 Mbit/s
2.23 Gbit/s*
1080p 8-bit
1.65 Gbit/s
4.95 Gbit/s*
1080p 12-bit DC
2.23 Gbit/s
6.49 Gbit/s*
Max HDMI
3.4 Gbit/s
10.2 Gbit/s*
1080p 8-bit 120Hz HDMI
4.98 Gbit/s
Acoustic Research $69.99 6' Pass Pass Pass Pass Pass
$79.99 12' Pass Pass Pass Pass Pass
$119.99 25' Pass Pass Fail Fail Fail
Blue Jeans Cable Series-1 $30 6' Pass Pass Pass Pass Pass
$51 15' Pass Pass Pass Pass Fail
$84.75 30' Pass Pass Pass Fail Fail
Cobalt Cable $74.95 2m Pass Pass Pass Pass Pass
$114.95 5m Pass Pass Pass Pass Fail
$179.95 10m Pass Fail Fail Fail Fail
DVIGear SHR $50 2m Pass Pass Pass Pass Pass
$90 5m Pass Pass Pass Pass Fail
$135 7.5m Pass Pass Pass Fail Fail
$175 10m Pass Pass Fail Fail Fail
Gefen $49 2m Pass Pass Pass Pass Fail
$219 30' Pass Pass Fail Fail Fail
Infinite Cables $10.95 6' Pass Pass Pass Pass Pass
$16.95 15' Pass Pass Pass Fail Fail
$77.95 15m Pass Fail Fail Fail Fail
MonoPrice $9.52 6' Pass Pass Pass Pass Pass
$15.81 15' Pass Pass Pass Pass Fail
$41.42 25' Pass Pass Pass Pass Fail
NGHP $50.95 1m Pass Pass Pass Pass Pass
$60.95 3m Pass Pass Pass Pass Fail
RAM Electronics $27.95 6' Pass Pass Pass Pass Pass
$49.95 15' Pass Pass Pass Pass Fail
$129.95 50' Fail Fail Fail Fail Fail
Tributaries $250 2m Pass Pass Pass Pass Pass
$450 6m NA NA NA NA NA
$900 15m Fail Fail Fail Fail Fail
WireWorld Starlight 5 $249.95 2m Pass Pass Pass Pass Pass
$399.95 5m Pass Pass Pass Pass Fail
$1399.95 12m Pass Fail Fail Fail Fail
Sewell Direct Vantora $39.95 2m Pass Pass Pass Pass Pass
Monster 500HD $69.95 2m Pass Pass Pass Pass Pass
$99.95 4m Pass Pass Pass Fail Fail
Monster 700HD $79.95 2m Pass Pass Pass Pass Pass
$119.95 4m Pass Pass Pass Pass Pass
$249.95 10m Pass Pass Fail Fail Fail
Monster 800HD $99.95 2m Pass Pass Pass Pass Pass
$149.95 4m Pass Pass Pass Pass Fail
Monster 1000HD $129.95 2m Pass Pass Pass Pass Pass
$199.95 4m Pass Pass Pass Pass Pass
$399.95 10m Pass Pass Pass Pass Fail
Monster m1000 $200 8' Pass Pass Pass Pass Pass
$250 16' Pass Pass Pass Pass Pass
*For reasons unknown to us, some manufacturers like to express the data rate as an aggregate number which combines the three primary high-speed data channels. In our opinion it's the "per channel" number that is significant. After all, we don't say that a stereo amplifier has a frequency bandwidth of 40kHz (if/when in fact each channel has a bandwidth of 20kHz.) In an attempt to be as thorough and helpful as possible, we have added the aggregate numbers to our chart as well.
What Does 'Fail' Mean?
It's important to define what we mean by "Fail'. The indicators above deal with the eye pattern on the Tektronix Digital Serial Analyzer. A 'Fail' on this chart does not necessarily mean that the cable will not pass the signal in the real world. In fact, see my Subjective summary below for some real "eye" openers (no pun intended… yes it was). The reason, quite simply, is that various electronics components have different levels of active compensation built in to help EQ incoming signals and help restructure HDMI signals into a more reliable stream. The axe swings the other way as well - we have no reason to believe the cables will reliably and consistently pass a signal to all types of components if they do not pass the eye pattern test above.
Every cable over 10 meters failed to pass 1080p, even at 8-bit, though Monster claims their m1000 Series can do just about anything (they didn't provide a cable over 10m to test and they don't sell it at lengths above 25 feet). At 10 meters the Monster Cable 700HD and 1000HD passes 8-bit, and we added Blue Jeans Cable (30 feet actually) and DVIGear. Blue Jeans, incidentally, uses a Belden-made HDMI cable. When we increased the bits to simulate 1080p at 12-bit Deep Color (similar to what's available in most HDMI 1.3a-rated products today) most manufacturers had to drop back to 5 meters to pass the signal. Blue Jeans passed it at 30 feet, but DVIGear requires their active cable solution to do a full 10 meters. Monster Cables' 1000HD cable also passed 1080p at 12-bit with no issues.
Recent Forum Posts:
mtrycrafts posts on September 04, 2011 19:23
Adam;828894
Shhhhh! I'm workin' here.
Hey, steveroland211, I've got some amazing high-value HDMI cables, only $100 for a six-footer. Your digital signals will come through totally unaltered. Pure A/V magic, I tell ya. I can get them to you in about a week, and I offer several different lengths and colors. Oh, and don't mind the markings. I just put "Monoprice" on the bags to keep my source confidential.
You need to get the signals there faster than light speed though. Then, it might be a good price.
Adam posts on September 03, 2011 19:48
Pyrrho;828891
You cannot see the difference in a short cable that costs less than $10 and an expensive one.
Pyrrho posts on September 03, 2011 19:37
steveroland211;823123
Everybody knows that you get what you pay for
That is the stupidest thing that people parrot back all the time. If it were true, there would be no such thing as a con or a bad deal, because you would always be getting what you paid for. No person with any sense who thinks about it even for a little while really believes it. If it were true, every ridiculous CD "demagnetizer" and other such worthless gizmos would actually work, and all of them would work in direct proportion to their cost. This is so freaking stupid it is amazing that people keep repeating it so much.
and this is true even with HDMI Cables, the materials that the cables are made from makes a difference on the way you will see it on your HDTV.
Simply put it this way, if you buy a $1,000+ HDTV is completely nonsense to buy a $10.00 cable!
You seriously need to read the article. You cannot see the difference in a short cable that costs less than $10 and an expensive one. With short distances, you can get an HDMI cable for less than a dollar a foot that will not visibly or audibly degrade the sound, and therefore spending more is a waste of money, even if you spent $10,000 on your TV. You are giving very bad advice that is total bullshit.
If you are going to invest on a good HDTV you better invest in as good HDMI cable that will assure you with the top quality imagine.
I’m an HDTV installer and I always recommend my customers to buy the top quality cables, but something is also true that should be always be keep in mind, not all the big name cables manufactures are good cables! I will recommend a top quality cable that is not easy to find but the quality is fantastic is called Obsidian HDMI cables by a company called Soncras.
You probably recommend that they waste their money on expensive cables because the markup tends to be higher on cables than on other things. It is a total scam, and either you are a con artist, or you are a sucker who is now misleading others. Either way, you are as wrong as you could possibly be. People would be much better advised to spend their money on better speakers or a better TV, things that will make an audible or visible difference, rather than on something that makes no audible or visible difference.
But, of course, the markup usually isn't as good on things that actually matter, and so we may expect that unscrupulous salesmen will continue to push nonsense about magical wires on unsuspecting customers.
highfigh posts on September 03, 2011 18:50
panzeroceania;526723
sorry, I'm not trying to troll, and I have found most the info out there, except the cable's gauge. That's the only thing I can't find. I somehow doubt that it is 16 as someone here as stated because it is no more bulky or stiff than my cables from other companies that are 22, sounds like a lie to make monster sound better. So far the best deals I can find are on monoprice, the best quality DVIgear, and the best standards meeting from bluejeancable.
I'm a facts guy, and never have any intention of causing any trouble, and can't understand people getting emotional about technology. I just like to gather data.
also in response to the thread you linked to, I'm don't have bose, I have a onkyo sound system . I don't have a lot of money to spend but I don't want my cables to be the weak link. I plan to someday get a 120hz or more television that supports deep color for when video games start supporting those features and don't feel like buying accessories twice.
This isn't high current signal, so wire gauge is of little importance. Since HDMI doesn't work via HDMI cable over extreme distance, anything more than about 50' is generally running on Cat5e or Cat6, which is usually 22ga. Now, HDMI over single coax exists and it's good to more than 300'. The biggest issues with HDMI, IMO- the connector sucks from a structural standpoint, the audio or video is subject to dropouts if the "handshake" drops below 4.7V (starting at 5V and allowing .3V volt drop isn't enough of a window to be practical) and the whole reason HDMI exists is so people can't copy Hollywood's crappy movies.
However, 120Hz isn't fast enough for clear video when the motion across the screen is extremely fast, so you might want to think about buying a plasma TV or something that's 3d capable which, by design, must be able to refresh much faster than 2d video needs. A 2d plasma will be less expensive than either a 2d or 3d LCD/LED if it's larger than 42" and capable of 1080p.
Fedaykin posts on September 03, 2011 18:21
Everybody knows that you get what you pay for and this is true even with HDMI Cables, the materials that the cables are made from makes a difference on the way you will see it on your HDTV.
Simply put it this way, if you buy a $1,000+ HDTV is completely nonsense to buy a $10.00 cable! If you are going to invest on a good HDTV you better invest in as good HDMI cable that will assure you with the top quality imagine.
Utter bullshit. HDMI is a digital interface. It's a completely different way of transmitting data over wires.
The primary benefit of a digital connection is error detection and correction. Data is sent over an HDMI cable in packets and each packet includes additional information to detect errors. If an error is detected, that packet is resent.
For example, if you want to send a particular chunk of data, such as:
1010110111011
Then an HDMI interface will transmit that data, plus additional information that describes that data without duplicating it: In my little toy example, we might have a simple check that counts the number of 1's in the code, in this case there are 9 ones. So the HDMI interface will send the following packet:
1010110111011 1001
where the additional 1001 at the end is a binary representation of the number 9. The receiving end will inspect each packet and make sure that the data portion and the error code portion still agree. Note, this is a very very simplistic example, the actual error detection codes are far more robust (i.e. this toy example would fail if an error occurred that didn't alter the total number of 1's)
In this way the error rate in a transmission can be essentially zero (you can resend a packet as many times as necessary to get it sent correctly). The trade off how fast that cable can transmit the data. The cables need to be able to transmit data very fast to allow the error correction to work without interrupting the real time display of your movie/music.
Luckily, the HDMI spec is not just really fast, it's blazing fast. A cable that actually meets the current HDMI 1.4a spec is supposed to be able to transmit at a rate of 10 billion bits per second (10gbps). How much is that? 10gbps is 1.25 Gigabytes per second (a byte is 8 bits), which is enough to transmit all the data on a double layer Blueray disc (50GB) in 40 seconds
This is roughly 500-1000x as fast as your "high speed" internet connection and 10-100 times faster than your average computer network. More importantly, this is roughly 200 times faster than necessary to transmit the Blueray data in real time allowing for plenty of time for error correction and other overhead.
This is why the HDMI cable makers are emphasizing bitrate -- it's really the only thing that matters for HDMI. Unfortunately for Monster and other fraudsters, as long as a cable actually meets the spec it's way more than is currently necessary, irregardless of price.
