You are here: Home AV University Audio Formats & Technology Issues with 0dBFS+ Levels On Digital Audio Playback Systems Issues with 0dBFS+ Levels On Digital Audio Playback Systems - page 3
by Chris Tham last modified April 10, 2008
Panasonic DVD-RP82, analog outputs, no upsampling
The Panasonic didn't do too badly, and was able to reproduce 0dBFS+ levels up to +1.1 dB FS:
Frequency (sine wave)
Phase
Analog peak level (theoretical)
Observed level
Relative level
997.0 Hz
0.00 dB FS
-7.5 dB FS
0.0 dB FS
5,512.5 Hz
67°
+0.69 dB FS
-6.9 dB FS
+0.6 dB FS
7,350.0 Hz
90°
+1.25 dB FS
-6.6 dB FS
+1.1 dB FS
11,025.0 Hz
45°
+3.00 dB FS
-6.6 dB FS
+1.1 dB FS
At levels higher than +1.1dB FS, the player started clipping, as can be seen for the waveform of the Sine wave @ 11,025 Hz 45° phase:
Panasonic DVD-RP82, analog outputs, upsampling using Remaster 1 algorithm
The Panasonic behaved far worse when the internal upsampling algorithm is engaged (I tried Remaster 1, but the other two algorithms were just as bad). The internal upsampler converts 44.1/16 to 88.2/24. It was only able to handle up to +0.1 to +0.3 dB FS:
Phase
Observed level
Relative level
997.0 Hz
0.00 dB FS
-7.5 dB FS
0.0 dB FS
5,512.5 Hz
67°
+0.69 dB FS
-7.4 dB FS
+0.1 dB FS
7,350.0 Hz
90°
+1.25 dB FS
-7.4 dB FS
+0.1 dB FS
11,025.0 Hz
45°
+3.00 dB FS
-7.2 dB FS
+0.3 dB FS
Here's how the player handled the waveform of the Sine wave @ 11,025 Hz 45° phase:
