You are here: Home What to Buy How to Shop What Size Screen or Television Do I Need?
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified February 21, 2008
What does "big screen" mean to you?
We get asked this question alot and we have, in fact, addressed it during the course of various projector and flat panel reviews. It is an important topic, however, and we feel that it is truly worthy of some personal attention - especially given these times of rapidly dropping flat panel display prices. While many believe that "bigger is always better," getting the right screen size means that you can truly optimize your home theater budget and allocate your money in the best way possible to make sure you get the best visuals and sound possible. We'll take you through several ways to effectively determine the best screen size for your room, and give you some general guidelines for figuring out your own needs.
So What's the Definition of Big Screen?
That's an excellent question and we're very glad you asked. The answer may surprise you. Everyone has a different idea of what "big screen" means. To the person who is coming off of a 32-inch CRT display, a 42-inch widescreen plasma might seem downright humongous. To someone who is used to the larger rear projection sets of the 80s and 90s, big screen has a different meaning. To find out what "big screen" means to you try this simple experiment:
  • Go to a movie theater when it's not terribly crowded and be sure to arrive early. A theater without stadium seating is preferred.
  • Find your favorite seat and watch the movie
  • After the film, count the number of steps it takes to get from the end of your aisle directly to the screen (remember this number)
  • Now go down to the front and count the number of steps it takes to get from the right side of the screen to the left.
  • Divide the distance away from the screen (in steps) by the movie screen width (in steps).
Using my own local cineplex I came up with these numbers (yours will likely differ substantially): 20 steps (from the screen to my aisle) divided by 10 steps (screen width) = 2.0
This number of 2.0 is your seating distance to screen width ratio. It simply means that I like to sit 2x the screen width away from the screen. That represents my perception of a "big screen". No one can determine this for you - you should do it for yourself - you may be surprised at what you find. Now, how does this translate to your living room? Easy. Just use the same formula.
Calculating Your Desired Screen Size
Let's say you sit approximately 8 feet away from your screen and you have the same preference as me above. Dividing 8 feet by 2.0 we get 4 feet or 48 inches - the approximate width of a 50-inch diagonal display. Keep in mind that many folks will find their desired "big screen" ratio is as high as 2.5. or 3.0, meaning that you might be fine with even a 42-inch screen from that distance.
Here are some recommendations based on some commonly preferred "big screen" sizes:
Viewing DIstance Big Screen (2.5x) Bigger Screen (2x) Really Big Screen (1.5x)
6 feet or less 27-inch 32-inch 50-inch
8 feet 40-inch 50-inch 67-inch
10 feet 50-inch 65-inch 82-inch
12 feet 60-inch 74-inch 100-inch
What you can note from the above chart is that some users will be very tempted to consider front projection systems if they have a tendency to want a really large screen and sit farther away. Currently rear projection microdisplays (DLP and LCoS) offer sizes up to 80-inches diagonal. Beyond that you will want to look at a projector and a means to control light in your viewing area. With the use of a retractable screen we've even seen plenty of consumers opt for a combination of both in the same room.
Why Isn't Bigger Always Better?
The reason there are even guidelines for screen sizing is due to the fact that if you put a screen that is truly too large for your viewing area you might end up seeing a little more than the filmmakers intended - such as film grain, noise and pixelation. Nobody wants to sit so close that they see the pixels on the screen - and with only 1920 x 1080 resolution (or less) the pixel sizing is fixed. This means that if you sit too close you may actually be able to see the pixels which make up the image on the screen. Keep back 1.5x the screen width almost guarantees this will never happen - especially on 1080p displays.
Personal preference is everything, which is why we first sggested establishing your concept of a "big screen" early in the process. If this chart doesn't seem to make sense in your room, then figure out whether you really want a bigger screen. I know one thing - we rarely encounter people who wish they had bought a smaller screen, so it's probably best to err on the side of going a bit larger.
Recent Forum Posts:
Big AV posts on October 15, 2009 13:09
I have a 55" screen and I am about 12 feet away and that works a treeat
HDPCsound posts on October 09, 2009 17:21
It depends, i always love to have a decent size Tv on my bedroom, but a bigger one on the living room. Is the one used for gaming, movies, etc.
audiohonic65 posts on October 09, 2009 04:57
Yes, bigger is better but it largely depends upon your room size.
PepperEvans posts on October 05, 2009 01:10
My hubby and I were told the size of one's TV should complement the size of the room. I think otherwise since big TV screens are always ideal whether for a big or small room.
drdawg posts on July 19, 2009 23:30
There is no such thing as too big!!! Actually I like this article alot and i did start with it as the basis but then we were at the store with the impression we should have gotten a 52-55 incher from the article but then we were there and saw a tv we loved. We asked how bit it was and were told it was 65 inches and then we had them measure from the tv to where we were standing and it was a foot less then we had in our place. We ended up buying it and if we bought the 55 incherr it would have been too small.
So my suggestion is use this article as a guide and then measure out the space in your room from the wall to the sitting area that you will most be using. Take into account also diagnols (you made need to measure distance from wall to couch area and then the height of where you are going to put the tv and then do the pythagoream theorem to find the diagnol length!)
if this blew your mind i am sorry to be a geek!
Come on we all remember this from geometry!!!!
Ketan
