You are here: Home What to Buy Calibration & Test Gear Sencore SP395 SoundPro Audio Integrator
by Clint DeBoer last modified June 26, 2007
Here's What The SP395 Audio Integrator Delivers:
Fast and accurate adjustments of speaker coverage and cluster alignment, time delays and speaker frequency response equalization; ensures a high-performance, problem free installation.
Tests and documents band-specific background noise, room reverberation, and speech intelligibility to identify problem areas and sign-off the system installation.
Easy to use and interpret user-interface helps you quickly make the test and get the readings you need.
Portable, battery operated (5 hours run time) and handheld instrument in a ruggedized case means you can make precise audio system measurements wherever you do audio system installations.
Optional software feature add-ons such as speech intelligibility, time delay analysis and more mean you are never caught short.
