Features & Specifications
0.3Hz ~ 3MHz Frequency Range
Sine, Square, Triangle, Ramp, TTL and CMOS Output Waveforms
External Voltage Controlled Frequency (VCF) Function
Duty Cycle Control with Signal Inversion Capability
Variable DC Offset Control
- Two Step (-20dB x 2) and Variable Attenuator
Built-in 6 Digit Counter with INT/EXT Function up to 150MHz
Specifications
| Main Output | Frequency Range: | 0.3Hz ~ 3MHz in 7 ranges | |
| Amplitude: | > 10Vpp (into 50W load) | ||
| Impedance: | 50W ±10% | ||
| Attenuator: | -20dB ±1dB x 2 | ||
| DC Offset: | <-5V ~ >+5V (into 50W load) | ||
| Duty Control: | 80% : 20% : 80% to 1MHz continually variable | ||
| Display: | 6 digit LED display | ||
| Sine Wave | Distortion: | £1%, 0.3Hz ~ 200kHz THD £ -35dB fundamental in all ranges (specification applied from MAX to 1/10 level) | |
| Flatness: | <0.3dB, 0.3Hz ~ 300kHz > <0.5dB, 300kHz ~ 3MHz | ||
| Triangle Wave | Linearity: | ³98% 0.3Hz to 100kHz > ³95% 100kHz to 3MHz | |
| Square Wave | Symmetry: | ±2% 0.3Hz ~ 100kHz | |
| Rise/Fall Time: | £100ns at maximum output (into 50W load) | ||
| CMOS Output | Level: | 4Vpp ±1Vpp ~ 14.5Vpp ±0.5Vpp adjustable | |
| Rise/Fall Time: | £120ns | ||
| TTL Output | Level: | ³3Vpp | |
| Fan Out: | 20 TTL Loads | ||
| Rise/Fall Time: | £25ns | ||
| VCF | Input Voltage: | 0V ~ 10V ±1V (100:1) | |
| Input Impedance: | 10kW ±10% | ||
| Frequency Counter | INT/EXT: | Switch selectable | |
| Range: | 0.3Hz to 3MHz (EXT 5Hz ~ 150MHz) | ||
| Accuracy: | Time base accuracy ±1 count | ||
| Time Base: | ±20ppm (23°C ±5°C) after 30 minutes warm up | ||
| Resolution: | Maximum resolution is 10nHz for 1Hz and 0.1Hz for 100MHz | ||
| Input Impedance: | 1MW // 150pF | ||
| Sensitivity: | £35mVrms (5Hz ~ 100MHz) > £45mVrms (100MHz ~ 150MHz) | ||
| Other Details | Power Source: | AC 115V/230V ±15%, 50/60Hz | |
| Accessories: | Power cord x 1, Instruction manual x 1, Test Lead (type GTL-101) x 2 | ||
| Dimensions: | 251mm (w) x 91mm (h) x 291mm (d) | ||
| Weight: | 2.1kg approx |
