You are here: Home What to Buy Calibration & Test Gear Datacolor SpyderTV Calibration System Reporting SpyderTV Results, Reporting & Conclusion
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified July 23, 2009
Results were positive, though on the LCD television I currently have in-house, I was not terribly impressed by the black level capability. Apparently, SpyderTV wasn't either, as it made no significant adjustments and the set still has difficulty showing a great amount of detail in dark picture areas. Here is a peek at the "Before and After" photos supplied by the SpyderTV DVD:
Before
After
I realize it's hard to tell from some of these pictures (and taking a "direct-on" shot with an LCD camera to an LCD screen resulted in a wonderful effect I like to call "Rainbow-Vision"), but the SpyderTV system really did an amazing job at correcting white levels. Skin tones lost an almost bluish tinge and whites took on a warmer tone (though watching it I though maybe a bit too warm.) Black levels, as I mentioned, remained a problem, though the bluish tinge was removed 舑 and you cannot expect the SpyderTV to compensate for inherent difficulties encountered by a particular television.
Summary Reporting
image011_008.jpgThe entire user calibration process took me 26 minutes and 5 seconds according to the Summary Report. You can print or create a PDF of the report for later reference.
At first, the summary charts didn't seem to mean much of anything, having two axes labeled "Slider Value" and Activation". After speaking with Datacolor about this, I realized that I was perhaps "looking at the moon with a microscope". Taking another pass I could see that the Color Setting Graph quite simply showed the Color adjustment potential vs. the slider value range.
The Proton LCD TV I was using limited the adjustability of the Color control (this is good, actually) meaning that while I had a more steep adjustment range (i.e. all settings higher than -12 do virtually nothing) I was actually able to get pretty close to the target setting.
image012_015.jpgThe Color Temperature Pre-set Setting Graph was nice in that it showed a target with all three settings represented. While an actual color temperature reading would be a welcome "educational" addition, most should find it helpful in showing (quite simply and clearly) that there was an improvement. Black and white luminance values were also shown at the end. According to SpyderTV the final ANSI contrast ratio for this set was 296:1 (black luminance level / white luminance level).
At this point the calibration session was completed. Should you want to calibrate another television, simply begin again and the SpyderTV system allows you to enter in new information for another TV set. Unfortunately, if you need to go back to a previous television, you'll need to re-enter all of the "Record Your Settings" info again. We're hoping that a software update will be released in the near future to allow users to store multiple display settings.
For the price of a TV stand (or a short esoteric component video cable) you can make your TV really shine. To spend thousands of dollars on a high definition television set and then live with the default factory settings should be a crime. The difference between a well-calibrated television and an oversaturated, blue-tinged torch is simply amazing for those who have never seen it. While a professional calibrator can do even more for you due to a wealth of additional controls available in the service menus, many will be satisfied to know that they can buy a single product that can be used to perform basic user calibrations on all the television sets in a home and be kept handy for whenever a new product such as a DVD player is added into the system. Now, if only the SpyderTV owners would rise up and take their colorimeters into the local consumer electronics chain store...
Datacolor SpyderTV
MSRP: $269
Datacolor Corporate Headquarters
5 Princess Road
Lawrenceville, NJ 08648
(609) 924-2189
http://www.datacolor.com
About Datacolor
Founded in 1970 and headquartered in Lawrenceville , NJ , USA , Datacolor is a global leader in color management and color communications technology. Datacolor initially developed solutions for industrial color problems, and then expanded its product offering to include color communication and digital imaging solutions. Today Datacolor SPECTRU M 蒂 provides an integrated suite of software products, measuring systems, and supporting services that provide centralized control of the entire color management process worldwide.
ColorVision , a unit of Datacolor, is dedicated to providing affordable, simple-to-use color matching tools to creative professionals, digital photographers, and consumers. We offer award winning products for monitor calibration, printer calibration, and ICC profile editing.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Ease of Setup/Programming/IntegrationStarStarStar
FeaturesStarStarStar
PerformanceStarStarStarStar
ValueStarStarStarStar
