Features & Benefits
>Key features:<strong>
> <ul><li>Goal-oriented, wizard-based color measurement tool <li>
<strong>
Key benefits:
<p>
- Optimize LCD, RPTV, front projector, plasma or direct view sets
- Enhance the depth and realism of the image by maximizing contrast
- Correct the new set from its 'torch mode' state used for display on showroom floors
- Minimize unnatural black crushing
- Remove the "Blue push" present in many displays
- Improve 'Dark Surround' viewing when the display is watched in a dark room
- Calibrate the display to the entire video chain... all the way from DVD to screen
- Reproduce the vision of a film director by using the same industry standards
- Turn business displays into home theater performers
><p>
Supported Products:
<p>
- GretagMacbeth Eye-One Monitor (w/ spectral graphing)
- GretagMacbeth EyeOne Display
- GretagMacbeth / McMahon LightSpex (intentionally disabled)
- PhotoResearch PR-650 (w/ spectral graphing)
- ColorVision Spyder (originally resold slightly modified as the "Optimagery Sensor")
- ColorVision Spyder2
- Minolta CL-200 handheld chroma meter
- Minolta CS-100A through-the-lens colorimeter
- Minolta CA-210 LCD "box" colorimeter
- Minolta CA-100 colorimeter
- Minolta CA-110
- Minolta CS-1000 1 nm resolution spectroradiometer (w/spectral graphing)
- Milori Trichromat-1 (rebranded Sequel Imaging Chroma 4)
- Generic, non-password protected Sequel Imaging Chroma driver (supports Sencore ColorLabs probes cp-288 and cp-5000)
- Progressive Labs password protected CA-1 (intentionally disabled)
- OCLI MicroPac (not commercially available, intentionally disabled, w/spectral graphing)
- Manual Meter (values may be typed in from any instrument for which XYZ or xyY values are obtainable)
- Simulated Meter (a "smart" random number generator produces software generated readings for display)
Each meter can be independently turned "on" or "off" with registration settings that are centrally controlled.
<p>
Signal generators supported by ColorFacts Professional:
<p>
- Sencore VP300
- Sencore VP400, 401, 402, 403
- QuantumData 802 series
- Accupel HDG-3000
- Computer Video Card
- External test disc (Avia, AVIA Pro, Digital Video Essentials, PF Test Disc)
