You are here: Home What to Buy Calibration & Test Gear AVIA Pro by Ovation Multimedia Sample Test Patterns
by Clint DeBoer last modified November 09, 2006
  • Temporal Dither and Color Separation Artifact Detection
  • Display Panel Uniformity
  • Display Contrast (On/Off, ANSI, Multi-check, etc.)
  • Light output
  • Panel Response Lag Time
  • Color Gamut Test
  • Color Wheel Speed Measurement
  • DVD Player Layer Change Delay Measurement
  • Color Upscale Error Test
  • RGB Legal, Y/Cb/Cr Bowties for Delay Measurements
  • Luma and Chroma Moving Zone Plates in Video and Film Motion.
  • Chroma Sweeps & Multipulses (Including Polyphasic sweeps to Nyquist Limit)
  • Luma Sweeps & Multipulses (Including Polyphasic sweeps to Nyquist Limit)
  • Variable Intensity Color Bars\
  • Vectorscope Grid Test
  • Above White Signal Handling
  • Below-Black Signal Handling
  • Black and White Clipping Tests Built into Multiple Patterns
  • Black Level Checks built into Gray Windows
  • Monotonicity Tests to Single Bit Count
  • Color Decoder Accuracy Checks
  • DVD Player Pixel Cropping
  • Gamma Response and Linearity to Light Test
  • Grayscale Banding
  • Grayscale Windows from 2.5 to 107.5 IRE
  • Automated Grayscale Measurement (when used with compatible instrument)
  • High Resolution Focus Patterns
  • Saturation and Hue Checkerboard
  • Scaler Light Linearity
  • Scaler Pixel Mapping
  • Screen Hotspotting Check
  • Tinted, Multicolored, or Variable Sized Hatches for RGB convergence
  • Variable APL DC Restoration
  • Variable Count Checkerboards
  • Checkerboards with Deep and Shallow Ramps
  • Variable Size Circlehatches
